Cannot print through cloud
Looks like it is fixed now.
I have the same problem, the print is sent to the sd card but it does not start automatically.
I think everybody has this issue. Please solve it as soon as soon as possible.
Status indicates: „cloud services operational“, „no incidents“
Does Bambu Lab ignore our complaint??
It works for me.
Try to restart printer and Bambu Studio.
I have exactly the same problem :face_with_head_bandage:
Hello,
We apologize for the downtime period. Please note that the issue has been solved, so there should be no other problem with starting print.
If you still have issues, please try the following:
  • Reboot the printer
  • Log off from the printer and the slicer, then log in again
  • Ensure that the network connection is active.
In case the problem persists, open a new ticket and our CS team will help
Thanks
Ciprian
There was a partial outage displayed which has been fixed this morning.
Im having a " Failed to Connect to the Server" error message, therefore i cannot print through cloud. Have to send file via FTP. i’m wondering if its the same issue as described in this thread.
try to do this:
 Reboot the printer
it worked for me. Prints from PC.
I got the same issue lucky iam a pc technical myself but took me long to sovle it because I never thought this could be possible but:
Solution : you have something near you router what is interference the 2.4ghz network that happens due of small electric machines near the router solve the interference and you are good to g go in my case it was 2 raspberry pi s.
Glad I could help you with this.
It was so strange because the printer was connected but I could not ping it and it log out my bambu account always
But lucky I solved it
Thanks it worked. i think the log out / relog in from bambu studio was what i needed.
There is absolutely no need to use external cloud service to send a print job to a printer located in the same local network. BambuLab if you are listening please allow for this simple option, you’ll save bandwidth costs in the process while doing us a favor.
I am having this issue, but seems its all fixed for you guys. The server status says no issues, I have a p1s running latest firmware and I use the latest studio. Just me or re others in the same boat?
Best,
Darren
I have the same problem. Bambu Studio and Bambu Handy both have no connection to the cloud right now.
Yep, problem here as well this morning. Was working around 5am EST, but it crashed in the past half hour or so. I reinstalled BS which was kind of a mistake as it also cannot download the network plugin, and downloading it manually using their guide here:
Yep same here, network down, did work once this morning but now the cloud isnt seeing any printers.
[2023-08-15 12:52:40.949535 +02:00] [E] [T 70660]: get_setting_list failed!, status=404, body={"error_msg":"404 Route Not Found"}
, error=
[2023-08-15 12:52:40.949815 +02:00] [E] [T 70660]: bambu_network_get_setting_list, get_setting_list returned error:404
[2023-08-15 12:52:48.386274 +02:00] [I] [T 48596]: set_on_http_error_fn
[2023-08-15 12:52:48.386283 +02:00] [I] [T 48596]: ssdp: stop()
[2023-08-15 12:52:48.399074 +02:00] [I] [T 48596]: SsdpDiscovery:start_ssdp with card number = 9
[2023-08-15 12:52:48.399164 +02:00] [I] [T 48596]: SsdpDiscovery::start_discover(), create thread 0
[2023-08-15 12:52:48.399219 +02:00] [I] [T 48596]: SsdpDiscovery::start_discover(), create thread 1
[2023-08-15 12:52:48.399277 +02:00] [I] [T 48596]: SsdpDiscovery::start_discover(), create thread 2
[2023-08-15 12:52:48.399330 +02:00] [I] [T 48596]: SsdpDiscovery::start_discover(), create thread 3
[2023-08-15 12:52:48.399378 +02:00] [I] [T 48596]: SsdpDiscovery::start_discover(), create thread 4
[2023-08-15 12:52:48.399435 +02:00] [I] [T 48596]: SsdpDiscovery::start_discover(), create thread 5
[2023-08-15 12:52:48.399488 +02:00] [I] [T 48596]: SsdpDiscovery::start_discover(), create thread 6
[2023-08-15 12:52:48.399570 +02:00] [I] [T 48596]: SsdpDiscovery::start_discover(), create thread 7
[2023-08-15 12:52:48.399623 +02:00] [I] [T 48596]: SsdpDiscovery::start_discover(), create thread 8
[2023-08-15 12:52:49.167729 +02:00] [I] [T 48596]: connect_cloud_mqtt
[2023-08-15 12:52:49.625489 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:49.864183 +02:00] [E] [T 95344]: get_print_info failed!, status=404, body={"error_msg":"404 Route Not Found"}
, error=
[2023-08-15 12:52:49.864418 +02:00] [E] [T 95344]: bambu_network_get_user_print_info, get_user_print_info returned error:-1
[2023-08-15 12:52:50.120454 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:50.604370 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:50.797471 +02:00] [I] [T 85352]: cloud_conn_callback::on_success, Connection(mqtt) OK! cli id= slicer:451898643:0ce5
[2023-08-15 12:52:50.797632 +02:00] [I] [T 85352]: cloud_conn_callback::on_success, Connection(mqtt) OK! cli id= slicer:451898643:0ce5
[2023-08-15 12:52:50.797634 +02:00] [I] [T 85352]: cloud_conn_callback::connected!
[2023-08-15 12:52:50.797876 +02:00] [I] [T 48596]: set monitor machine =
[2023-08-15 12:52:50.797888 +02:00] [I] [T 48596]: Agent: save_config
[2023-08-15 12:52:50.798258 +02:00] [I] [T 48596]: set monitor machine =
[2023-08-15 12:52:50.798260 +02:00] [I] [T 48596]: Agent: save_config
[2023-08-15 12:52:50.798574 +02:00] [I] [T 48596]: set monitor machine =
[2023-08-15 12:52:50.798576 +02:00] [I] [T 48596]: Agent: save_config
[2023-08-15 12:52:51.093717 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:51.608434 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:52.109747 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:52.610942 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:53.123799 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:53.620858 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:54.462596 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:54.950268 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:55.447310 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:55.942774 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:56.431107 +02:00] [E] [T 79004]: get_user_track_url error = , body = , status = 503
[2023-08-15 12:52:56.890744 +02:00] [E] [T 59940]: get_print_info failed!, status=404, body={"error_msg":"404 Route Not Found"}
this is what I got in Bambu Studio logs
All showing as ‘operational’
Yeah, no.
My Printer will not connect to either the Handy or Studio software (both Windows and Mac) at all and cannot print.
