Can't send print-jobs without LAN-only mode (Storage Test Failed)
Everytime I want to send a print job to my P1S with AMS, the job gets stuck at 2.9 MB - 3.4 MB and stops sending. Then it retries and after some tries it says failed to send job.
Fehler
I did reconnect my account and the printer, restarted my router and all the suggested troubleshooting guides. Still no effect. It can’t be the WiFi since in LAN Only everything works fine. Also the network test says something about the storage - and storage upgrade test failed. What could be the error?
Log:
Sat Jun 08 10:12:08:test bambulab start…
Sat Jun 08 10:12:08:[test_bambulab]: url=https://api.bambulab.com/v1/iot-service/api/slicer/resource?name=slicer&version=01.09.01.66&guide_version=00.00.00.01
Sat Jun 08 10:12:08:test http start…
Sat Jun 08 10:12:08:test bing start…
Sat Jun 08 10:12:08:[test_bing]: url=http://www.bing.com/
Sat Jun 08 10:12:08:test storage upgrade start…
Sat Jun 08 10:12:08:[test_oss_upgrade]: url=http://upgrade-file.bambulab.com
Sat Jun 08 10:12:08:test storage download start…
Sat Jun 08 10:12:08:test plugin download start…
Sat Jun 08 10:12:08:[test_oss_download]: url=https://api.bambulab.com/v1/iot-service/api/slicer/resource?slicer/plugins/cloud=01.09.01.00
Sat Jun 08 10:12:08:test storage start…
Sat Jun 08 10:12:08:[test_oss]: url=http://upload-file.bambulab.com
Sat Jun 08 10:12:09:test bing ip resolved = 88.221.221.131
Sat Jun 08 10:12:09:test bing ok
Sat Jun 08 10:12:09:test http ok
Sat Jun 08 10:12:09:[test_plugin_download]: downloadurl=https://public-cdn.bblmw.com/upgrade/studio/plugins/01.09.01.06/771c19086f/win_01.09.01.06.zip
Sat Jun 08 10:12:09:test bambulab ip resolved = 104.18.3.216
Sat Jun 08 10:12:09:test bambulab ok
Sat Jun 08 10:12:09:downloading 5%
Sat Jun 08 10:12:09:downloading 10%
Sat Jun 08 10:12:09:downloading 20%
Sat Jun 08 10:12:09:downloading 15%
Sat Jun 08 10:12:09:downloading 30%
Sat Jun 08 10:12:09:downloading 25%
Sat Jun 08 10:12:09:downloading 40%
Sat Jun 08 10:12:09:downloading 35%
Sat Jun 08 10:12:09:downloading 50%
Sat Jun 08 10:12:09:downloading 45%
Sat Jun 08 10:12:09:downloading 60%
Sat Jun 08 10:12:09:downloading 55%
Sat Jun 08 10:12:09:downloading 70%
Sat Jun 08 10:12:09:test storage upgrade failed
Sat Jun 08 10:12:09:status=404, body={“error_msg”:“404 Route Not Found”}
, error=
Sat Jun 08 10:12:09:downloading 80%
Sat Jun 08 10:12:09:downloading 65%
Sat Jun 08 10:12:09:downloading 75%
Sat Jun 08 10:12:09:downloading 90%
Sat Jun 08 10:12:09:downloading 85%
Sat Jun 08 10:12:09:downloading 95%
Sat Jun 08 10:12:09:downloading 100%
Sat Jun 08 10:12:09:test plugin download ok
Sat Jun 08 10:12:09:test storage download ok
Sat Jun 08 10:12:09:test storage failed
, error=
Thanks in advance for all your help
The printer caches data on the SD card. Have you tried reformatting the card ‘inside’ the printer? If there are some bad blocks on your SD card, that could explain the results you’re experiencing. At any rate, formatting the card is an easy troubleshooting step. Also, you may want to try another SD card just for eliminating any possibility of a defective card. Please let us know if you tried that and if it works. Good luck. :four_leaf_clover:
I tried reformating the SD-Card and switching it out for another SD-Card. No change in the behaviour. The task still fails, if the file is larger than ~2,3 MB
An interesting observation: I CAN send print jobs from my phone, the problem seems to be on my PC somehow :X
It seems like you’ve done the logical troubleshooting steps then. One last thing you may want to try in order to simply rule out a corrupt Gcode or 3MF, is to place the SD Card in your computer and send the files directly to that. Then simply plug it into the printer directly, navigate to the menu and verify that it can print.
In case you haven’t used that feature before, it can be a bit tricky to find so here it is:
  1. Select it from the print menu
  2. Slice Plate.
  3. Click on ‘Export All Sliced file’ which will bring up a dialogue box of where to save it and just save it directly to your SD card.
Now the only thing this will prove is that your file isn’t corrupt. Note, don’t be surprised if the printer goes through the leveling process because when you print from the printer’s control panel menu, I do not believe there is an option to disable that.
Here’s the wiki on printing from the SD card just in case.
I already ruled out the GCODE since the same model worked in LAN-Only and also when I start it from my smartphone. The issue seems to be some networking-issue on my PC and Bambu Studio
It seems you’ve narrowed it down to a configuration issue with your system. I had a similar problem two weeks ago with my P1 due to a faulty SD card. After fixing that, I couldn’t reconnect in LAN-only mode. Back in September, upgrading from 1.3 to 1.5 was unstable, so I downgraded to 1.4, which was more stable. Bambu wouldn’t let me revert to 1.3, and now they only support 1.41.
I only mention this because my September experience may offer a possible alternative. Maybe try downgrading the firmware to see if it reinitializes the base controller board settings. While it’s a long shot, it may be worth a try.
When I had my SD card issue two weeks ago, I wasted a lot of time. Fixing the SD card only revealed that my controller board configuration somehow became corrupted. I was unable to connect either LAN-only or even through Handy. After wasted hours, what finally worked for me was reverting to factory defaults and starting the pairing process as if it were a brand-new printer. Bambu doesn’t offer decent diagnostics, so I had to try different pairing sequences to get it working in Cloud mode. After successfully connecting via the cloud, I waited 24 hours of using the printer in Cloud mode to ensure stability before attempting LAN-only mode. It has been stable now for two weeks. No thanks to Bambu BTW, I’m sure I would have waited days for a response if I opened a ticket and would still be exchanging emails with them. I’ve found that their answer for everything is “send us your logs”.
Did you ever get a fix to this? I’ve had this issue come up twice now, both after I’ve experienced Internet outages.
The first time it seemed to fix itself after I sent a print from my phone through the app.
Now nothing I do seems to fix the issue.
I’ve:
-restarted studio, the printer, my router/modem, my PC.
-unpaired the printer from the screen, my PC, my phone
-factory reset the printer
-uninstalled studio including deleting user files
-reinstalled studio (3 different versions)
-checked firewall, whitelist, router configs for hangups
-reformatted the SD card, used a different SD card
-updated firmware for both router and modem
I can get it to print through the app with no issue. I cannot get it to print through studio using cloud. I can however change from “print” to “send” and then see the file on the printer.
I can put the printer into LAN only mode and then print from studio with no issue. I’m frequently out of the house though so I like to be able to check prints from my phone so this doesn’t work long term.
According to the website there is no outage on the cloud service at this time.
The message that I get is that the storage rest is getting a 404 not found message for a url it won’t let me post but is basically upload a file at Bambu dot com
Attempting to visit that url also gives me a 404 not find via browser but I’m not sure it’s actually supposed to work via a browser ?
I’m hoping it will resolve itself like it did the first time. But as it’s now been 18 hours I’m sort of doubting it. Any thoughts to what I might have missed?
Did anyone in this thread ever figure it out? This started happening to me this yesterday afternoon. I assumed it was a problem with the Bambu servers since it’s failing at a specific upload-file.bambulab address, but their status page shows everything is working fine, so now I’m wondering if it’s a me issue.
Yes same exact problem here. Multiple printers logged in to same local network, tried new sd cards and formatting, tried uninstall reinstall, rebinding printers, deleting user data but always comes back up with the same problem. Cannot send to printer. All network tests pass excetp test storage upload and test storage upgrade both fail. Please help, Bambu Lab!! SOS SOS
Also having the same problem on multiple printers, have tried multiple uninstall/reinstalls, resets and SD cards and nothing seems to work
Same exact problem here. Multiple printers logged in to same local network. HELP!!!
I had the same problem today. I don’t know how to solve this problem.
As corny as it may sound, formatting the SD card helped me out. I have two printers; I put a formatted card in one and a new SD card in the other, and they both worked fine.
I’m having the same issue. I tried formatting the SD card but that did not help. I printed from my phone the other day so I know it’s somehow the connection from my PC to my printer. Yet I can look through the camera live in Bambu Studio but just fails to print. I finally just changed to LAN mode and now it’s printing. But this is super frustrating. I’m wondering if it’s this version of software because I just reinstalled Windows and downloaded the newest version of BS, and that’s when it started happening. Worked fine before on this same PC.
I am having the same problem. Any ideas?
any updates on this matter. I am running into the same issue
Same here, anybody any closer to a solution ?
i can not resolver upload-file.bambulab.com.
and online DNS query says no A record etc. found.
Hi all. Any resolve with this? I have had to manually print for a week now. No help with support ticket.
