Changing colors mid print
Is there a way to change filament color mid print with-out pausing and manually changing over?
Without an AMS you will have to pause unless you want to be risky and try to manually cut off the feeding filament and then manually feed the next color in as it continues to print. This will give you less control over perfect color changes on a new layer though. I used to do it all the time on my old printers. I am not 100% positive that the Bambu will fall for this back door trick. Maybe it’s worth a shot though for you.
Sorry guys, I hate to hijack. But is it normal to not be able to add a new topic in this forum?
Thanks so much.
And if you have an AMS just do it from here
It’s normal when you’re still classified as a “New User”. Hang out for a bit and read some threads (like this one) and you will move on to the next level which allows you to post topics.
I may have done it the hard way, but I figured it out.
How do you set a pause point?
You click slice then go to the bar on the right and right click and “add pause”
is there a way to change filament in Studio mid print? my AMS automatically swapped to a different colour when the current one broke. Studio wouldn’t let me override, i had to cut the new filament and feed in the old to revert to the original colour. Surely by pausing the print, you should be able to control the filament on-screen ?? instead the buttons are greyed out and the print is locked to the current feed.
