Changing flow rate defeats AMS auto-refill groups?
I’ve loaded up the AMS with the same filament type and color and made the correct adjustments in the device and slicer selection so that prints should continue across spools. And this works fine as long as I don’t change the flow rate on the filament. This is crucial for my prints because the filament settings are woefully low for the 0.6 nozzle. The profile defaults to 12 or 15, but I can easily print at 20 which cuts hours off my print times. But then AMS stops seeing all the spools as the same and this seems like a bug. Is there a workaround?
