I am thinking about buying an H2S to replace my Qidi Plus 4 that bricked suddenly at roughly 2 years of use. I have an A1 and I like it. The H2S has the build volume and heated chamber that I need for ASA prints but I am concerned after reading comments about heat creep, abnormally high chamber temperature alarms and extruder clogs when printing PETG and the process to resolve it. I would like to hear from some H2S users about their experience and what I should expect if I decide to buy one.
It isn’t noteworthy when a print goes as expected.
Two posts really shouldn’t be compelling data points in your purchase decision, particularly when one has nowhere near enough info and OP never reported back on the end result.
That said, wait until after Nov. 3 before making any decisions.
Abnormal chamber temperature can only be lemon units. Two H2S, combined 2000+ hours, never seen it. Again, if the reports concern you, just make sure you are able to pack & return on time (instead of leaving it unopened past the date)
PETGs alone have 1000+ hours on mine, never clogged. Clogs are nasty but usually user errors, or compounded from kept trying to print before fixing a machine (say, loose nozzles, bed that needs tramming)
I also had a QIDI Plus 4 that I bought from a friend. It had a problem with the mounting of the print head. I got a new mount from QIDI and glued it on newly, then it worked. As the QIDI box was not available I sold it. Before that I already bought the H2S. It is a much better printer. Now I have about 1000 hours on it. Printer works very well, but I should have bought the H2D as I miss a second nozzle for a separation layer for support. Prints perfectly. Most thing I print with PETG (Elegoo Rapid PETG, BambuLab PETG HF and now Basic) and QIDI ASA. QIDI ASA is very good to print - no warping and good adhesion. As well for PC CF it is very to use. I bought some eSun PC CF for some Rasperry Pi KVM for which ASA is not optimal as is weakens when the RPI is fully utililized.
I had my eye on the H2S for a long time, but earlier this year bought the H2D when it went on sale. It depends on your use case, but having the second nozzle is nice. I have a few hundred hours on it with no issues at all with a mix of PLA and engineering materials.
At this point I would wait for Bambu’s new releases and see where things stand.
The H2S is the going to be the cheapest it’s ever been soon for the sale, £1k for the combo is mint.
I have 2 of them, alongside a H2C and I genuinely prefer the H2S purely because its just robust and can crack out some huge prints without a fuss. I have my tree supports dialled in so nicely that I personally don’t see the benefit of the extra time/material using 2 nozzles for interface supports that I can use on the H2C. Got about 4k hours total on both machines now and would have another in a heartbeat. Never had the creep issues you talk about.
In ~400 hours over the last 30 days with this H2S every single issue I have had has been my own fault, one way or another. So far:
Used 10 year old PLA that printed fine but broke in the base of the AMS on it’s first unload retract.
Using cardboard spools of ABS that, due to the lower density fill the roll to the point of contacting the AMS drive unit (not a problem for the HT FYI!).
Forgetting to take the PTFE tube out of the chain.
Forgetting to put the PTFE tube back in the chain.
Doing a bad job cleaning the PEI plate.
Using the wrong plate type because I wanted to try it.
Jumping the gun on wet PACF instead of waiting until morning to start it.
Moved the AMS out of my way and kinked the PTFE.
Disconnected the AMS from the PTFE, forgot, and tried to start a print.
Didn’t follow the order of operations for changing filament. Turned into a highly manual process.
Lifted a spool out of the AMS HT to shove desiccant in and snapped the ASA off in the inlet. Twice.
Incorrect bed temperature settings for non-bambu filaments (no, this is not the fault of Bambu’s profiles).
I am sure there’s several more I have forgotten about already.
First, I just want to commend you on saying this. 3D printing is hard, it’s a very technical process, Bambu and the rest of the industry have done a lot to make it easier to learn and do, we’re light years ahead of where we were ten years ago even, but it’s still really hard. If anything we’ve swapped complicated and tricky processes for complicated machinery.
I’ve made all these mistakes too, and more. Sometimes more than once. We learn by making mistakes - and the people who can best recognize their mistakes are usually the ones who learn fastest and grow the most.
It’s funny…from time to time there are angry help request/rant posts that may be down to relatively basic user errors…I try not to antagonize too much, but sometimes I’ll ask a question pertaining to that error…and then
the poster just never responds to that thread again. I sometimes wonder if they just didn’t want to respond back admitting they were at fault, not the printer.
I’ve been printing for the last 11 years and still do this stuff on a regular basis. Almost every time it’s because I am in a hurry to get on to the next thing.
At least now I don’t have to spend so much time ‘calibrating’ filament profiles.
Like most of you, I started 10+ years ago with a Robox which required constant tinkering with both the machine and the print/filament profiles and I paid a small fortune for the privilege. I have owned 6 different printers in the meantime and I do plenty of research before plunking down my money. I read forum posts and reviews then make my decision realizing the user error and experience are a large part of complaints and issues.
The A1 has proven reliable and handles a lot of my day to day chores for printing simple prints using PLA. So, when the Qidi bricked, I naturally navigated to what has worked well for me. The H2S gives me all of the build volume and ability to print where a heated chamber is required and is similar to the Qidi in a lot of respects but it carries the reliability of a Bambu product. All of the comments have been very helpful and I appreciate the time all of you took to make them.
I have two H2Ds and love them. They’ve been my favorite printers. I have a H2S I dedicated to the laser unit, so haven’t printed on that one so much. I like printing ABS too and have printed it a lot on the H2D. Not as much ASA though.
I’m decently positive you’ll have a good experience with it.
I think with current offerings you should look strongly at the H2D instead of the H2S, but also maybe peek at the Qidi plus 5. I’m just some rando on the internet, but I’m here to tell you that greater than 1 toolhead/nozzle unlocks a lot of creative flexibility and if you’re flirting so close to it with the H2S, just go for the H2D. If your use case is high temp all the time, the qidi might be more suited, but its also new and an unknown. I too have a plus4 (pouring a drink out for your homie) and it has been nothing but good results in high temp.
Don’t see much areas to improve on another 1:1 dual extruder 3D printer, other than finally making a real 1:1 dual extruder on the smaller X series, an X3D if you will.
Or maybe Bambu could make a whole like of printers for enterprise use, with an airtight chamber and controlled environment. An E3D if you will (haha… “E3D”)
From my eyes, the H2D is perfect for what it stands for and unless some game-changing discovery is made in the dual extruder field, I say it needs no revision, maybe some add-ons, like a right aux fan, but definitley not anything that would change the anatomy of the H2D itself like how the H3C changed the H2C.
Just some random thing to put out there though, but they could be making both nozzles able to rotate along one gear and pinion so that they both share the exact same build volume, but that system may be too bulky to put on a toolhead to make it light and small enough to even add any build volume on the sides.
And I’d say market pushes companies (bambu) to make “new capacity” over “do the same role but better”. A bit oversimplified, certainly not mutually exclusive, but I’m highlighting the difference in reward (ability to sell).
Toolchanger is the new bling, regardless of if it actually significantly benefits people that don’t need low temp multi color / super softs.
Personally for what I care, over the H2D, a better belt to further reduce VFA zones; unlikely but an in-house PCD diamond nozzle for more stable thermal flow (reports of diamondback QC and unknown diameter consistency give me some pause). But yeah not a lot on the wishlist. Maybe Bambu will surprise me again, the H2 was so much more than just a bigger X1 with second extruder (comparing real results) but most of these were overlooked/dismissed at launch “it has the A1 nozzle / A1 mini prints even better” lol.
Totally unrelated, but xTool’s “all in one” X1 is also a “bling” that turns out has severe UV/fiber quality constraints over their existing standalone lasers hence this analogy being on my mind. (not implying H3C will similarly suck it’s not even fully announced)
