Hi all:
I got my A1 a couple of months ago, and worked fine for a while, but since a few weeks the prints constantly stop complaining about filament or extruder being stuck (AMS). The filament is Ok, I just hit retry and continues until fails again a few minutes later.
I tried cleaning the extruder as per the wiki, swapped the hotend, different filament, etc.
Filaments: PLA. Brands: Bambu Matte, Overture, eSun
Already logged a support ticket, just waiting for now.
Any ideas would be greatly appreciated.
LOL< I was just going to post the same thing, my AMS unit won’t advance, and the external is having the same problem after several fails on a PETG Filament on a little dummy 13 bot for the kids…grhhh!
Take a look at your ptfe tubes. If there is wear (ID getting larger) it will cause play that will make the printer think there’s an issue.
PTFE tubes are consumables. Depending on what your printing they will wear.
This thing is quite new, maybe ten things printed…just to experiment.
It seems to not be as reliable
As my P1P, and I just began using the AMS on the mini….so in trying to use the Petg for a different effect and to try out how it plays with PLA, I now have a mess. I read the Wiki, cause I gave up on repeated errors, and now I guess the unplug process will begin…I also tried the external spool holder and also to no avail. Bugger!
Is there a relationship between this problem and the angle that the ptfe tubes line up with the filament hub? The tubes are not at the same profile as the hub or different wording, the tubes don’t extend straight up from the hub. thanks.
Too sharp an angle would interfere with feeding. However it should throw an error if that’s the issue.
I forgot the A1 nozzle etc doens’t “plug in” (cables). Sorry I cruze the forums and forget to look at which one I’m on sometimes.
If it’s AMS related usually you get an issue. You should be getting an error. You may look carefully at the PTFE path from the AMS to the print head. I would try feeding from the external to see if/where the problem lies. If it feeds from the external then it’s the AMS. If it doesn’t then it’s the filament path/extruder/splitter.
The angle is not that great, maybe 1-3 degrees. I disassembled the hub and didn’t find any debris inside. I did find some sort of residue from one filament I used that is ‘tacky’. I used a nylon cleaning piece, which didn’t seem to cause an issue. How far into the hub should the ptfe tubes insert?
Believe it’s just like a mm or 2. It’s not very far. If you haven’t run a piece of fiament through all 4 all the way through.
Matter of fact, cut a piece about 50 or so mm and disconnect the hub and feed the filament directly through. If you’ve cleaned the extruder then it should feed through.
Also, you said you switched nozzles. Are you certain that nozzle isn’t clogged or was it new? Should have asked this first.
Yes, the nozzle is new. I have a backup and will try it. What is odd, is that this happens at the start of the print when I choose a different filament, so it has to go through the unload/load cycle. But occasionally it occurs in the middle of a print.
Also, thank you for your time and help with this.
What filament are you using?
Bambu and Overture, PLA 99% of prints. I printed two small pieces of TPU with no issues. Maybe two prints with PETG.
somewhere there’s a blockage. If the fialment is being loaded to the extruder but nothing is coming out, then it’s a clog or the extruder isn’t working. I think it was mentioned that you should be able to see the extruder moving. If it isn’t then there’s your problem, somethings been put together wrong. If it’s moving then the filament is skipping or there’s a clog.
double check your work.
I plan to find the issue or replace the tool completely. Thanks again for your help. Can I buy you a coffee or a beer, I feel obligated.
I’d feel better if you were actually printing.
The filament runnout is connected properly as well right?
Let us know when you find out what is causing the issue.
I just took a piece of filament like you mentioned previously and fed it into the hub with no ptfe. Cycled through a few extrusions and retractions with no issues. Now I have a spool fed into the hub without the AMS and no ptfe to try a small print job. Also using the same nozzle.
I had the same issue on my A1 as well. I followed some ideas from @R3d-Five and seem to have reached a fix. I hope you have had the same result with your issue.
i have a same A1 bambu works perfect now cloget all time whent filament change gonna return !
I’ve had my A1 for a week, and even using Bambu filament, this has happened 3 or 4 times already. One annoying thing is that the printer just keeps running indefinitely, with the bed heated. So, it failed an overnight 4-hour print right at the first layers while I was sleeping. The printer stayed on, waiting for me until morning.
We could really use a “timeout” option for these cases, or maybe the app could send more alerts.
Anyway, I think the AMS angle to the printer might be part of the issue. I’ll try angling it more toward the printer to reduce stress on the PTFE tubes. The system seems really sensitive to that.
Do you have the bed aligner installed on the back right side of the build plate? That seems to be causing the error when the hotend moves back to that corner to check if there is something there. If you have one installed, try removing it, and see if the error goes away. If so, and you still want to have a plate aligner, there is a newly designed one that is supposed to not cause the error.
