Cool Tack Plate help
Bambu Doesn’t have the super tack in stock for the H2… What aftermarket plate works well from amazon, etc, and is decently priced, thx Jim
I found the BIQU Glacier to be an excellent all-around smooth plate on my H2C, and it’s now pretty much my default go-to for most materials. If only printing PLA or PETG then the Frostbite might be a better choice (or get both, of course), but I can’t vouch for that. Both should be available from Amazon (or directly from BIQU US store). The SuperTack does have some serious grip, almost too much for PETG (removal can be tricky), which can be useful on especially difficult pieces, so I do enjoy having both available. For reference, I also own the Engineering plate and DarkMoon CFX and Satin plates, but those get much less use than the Glacier and the BL textured PEI.
HTH,
-Max
Kdeavi “Cryoclover” - the green one. The only plate you need (except for tpu) as it handles all materials (including abs/asa and nylon)
I have a glacier too. only use it for tpu now…
Well you did mention you were disappointed with the Glacier, which others tend to be happy with (I’ve not had any issue, w/out glue, besides some nylon as others have mentioned). But the CryoClover does sound and look pretty cool, so I just ordered one :slight_smile: (In stock @ Amazon in US, price comparable to SuperTack from BL store & much less than a Glacier.) A bit odd that PC isn’t mentioned anywhere and “PA6” is oddly specific… but hey.
I’m still looking for a perfect plate for foaming PEBA, since it tends to either lift at corners if not hot enough or stick a bit too much everywhere else on a hotter plate. (I realize the 'Clover isn’t it, most likely.)
What aftermarket plate works well…
BTW it might be worth mentioning that a lot of times one needs to just disable automatic build plate detection for 3rd party plates. Detection rates really seem to vary. Sometimes the code on the plates will just work… others swear by printed stickers or codes or whatnot. YMMV. I just disable the check. Then it also doesn’t matter which plate type is selected in the slicer, as long as the filament profile defines the desired temperatures for that selected plate.
-Max
I reckon you wont be disappointed.
I use 2 pc filaments some cheap no-brand generic pc and cc3d pc-petg blend.
The generic one only works for small parts, even with the kdeavi, but that material sticks to no other build plate material… at all!!.. nothing that i tried ever made it stick well… even garolite… nothing. Until i printed it on a raft of abs…
The cc3d stuff prints and sticks like petg, its just stronger (good stuff, i like to use it for most of my strong functional parts when i want good layer adhesion and rigidity without fibers.
the generic nylon i have sticks good (as well.as on garolite) sunlu easu-nylon sticks almost too well (plate needs to cool down, and i have tuned down bed temperature) inslogic pa6-cf sticks well too on generic settings.
pla sticks well at 30 degrees, petg at 50-60 abs at 90 (subject to part geometry you can go lower, i prefer my parts to stick well…)
Tpu would likely never come off, tpe (the generic stuff that I have - which appears to be way less sticky) does not stick to the glacier but works ok on the kdeavi
I believe that adhesion always also depends on the exact filament brand/formula (i.e. your nylons/pcs might behave differently)
the qr code for the h2d version has the coolplate supertack code and is recognized, but I have disabled build plate detection.
Regardimg the glacier, I find it just does not offer me any better adhesion as the stock pei (which I havent used in months), it certainly is not a cool plate. Good texture and looks cool though!
