Doesn't open multiple Bambu Studio instances + Copy/Paste Feature
Continuant la discussió de Importing Multiple Objects from Fusion 360 to Bambu Studio:
On MacOS when you export a STL file from Fusion 360 directly to BambuStudio, it adds the exported file on the last BS instance opened.
So, you can add multiple files/versions on the same BS Project.
But, ON WINDOWS doesn’t work by this way… :frowning:
  • if you have preferences options of only 1 BS instance can be opened at time, the workflow works like in MacOK
  • But, if you have enabled “mutiple BS instances” on preferences, then, each time do you export STL file from Fusion 360 it is opened to a new BS instance/project.
REQUESTS:
A) Always add exported STL file to the Last BS instance focused.
B) Allow to do Copy/Paste function BETWEEN different Bambu Studio opened instances.
Thank you,
