I was looking for some sort of Multimaterial printer and the x2d seems perfect for that. All the tool changer systems are kind off over the top for me.
Still wenn looking at the multicolor capabilities I was wondering if the dual nozzle uses the advantage of one AMS connected to each nozzle.
In theorie that would mean when for example switching from nozzle 1 to nozzle 2 it could also cut the Filament from nozzle 1 and while it is printing with nozzle 2 it could unload and load the new filament for nozzle 1.
Is the system already doing that? If so does it help alot? If Not am I missing a issue that comes with that Idea?
You can not load and unload material in one nozzle while the other is printing. As they are part from the same printing head, and load/un-load require the head to go to other areas for purge and cleaning. And this is not possible while printing on this printer. Some other printer which has two separate heads with their own nozzles, extruders, heaters and etc, maybe able to do that. But not the X2D.
So fo every color change you need to wait the head to stop printing, on one nozzle and switch to the other. If you do not change the material the switch is relatively fast. If you do change materials you need to wait for load/unload and other preparations.
So in theory X2D has advantage only when printing two colors, with supported materials. But also it had disadvantages as AUX do not support all materials and it is much slower.
Thanks for the help! I understand what you mean and that it is not really suited to do a lot of multi color prints.
So I was thinking it could delay the purge until it actually switches the nozzle again.
So while nozzle A ist printing, nozzle B switches the filament until the new one is right infront of the hotend.
When switching to nozzle B it only hast to purge the old filament since the new one is loaded. Doesn’t save Filament but maybe the filament change time
But since I don’t own that printer it is just a speculation. I don’t know hot it works in detail so I don’t know If my idea makes any sense. Like I said it would only save the time to load and unload the filament. I don’t know if that’s 5s 10s or 30s saved.
For switching filament, it also has to cut the loaded filament, which also doesn’t work while printing. The head has to move to the rear, where a small stub activates the cutting mechanism. So you already have two actions, cutting and purging, that can’t be done while printing. The most time consuming part of switching filament is the purging, so there is almost no time to be gained in the other actions.
The VORTEK (H2C) is basically this, to a first order approximation. You should also look at the Bambu Filament Track System that allows AMS-Nozzle connections to be switched.
If you doing multi-colour today, I would get a tool changer such as Snapnaker U1, Flashforge cant remember number, or the new Creality Sparx 8,
If you doing multi-colour tomorrow, who knows? New Bambu machines will probably be announced in November 2026.
If you are doing multi-material, I would get a Bambu. The snapmaker etc don’t like “engineering” filaments.
Oh okay I wasn’t aware that purging takes so long.
So my idea could work but the time saved would not be significant. Maybe only a few seconds.
When switching from nozzle A to B the head drives to the activator of the cutting mechanism and cuts filament A.
→ time lost
Then it drives to the switch position from nozzle A to B. It switches, purges etc. And starts printing
In parallel to point 2 the filament A from nozzle A gets unloaded and new filament is loaded to nozzle A. That works because nozzle a has its own Extruder and AMS.
→ time saved
Then B will purge etc. and print
When switching back from nozzle B to A. Only purging is required since the filament is already loaded
→ time saved
(Point 1 and 5 equal each other out)
Yeah the vortex seems to help with the biggest time-consuming issue. The purging. But I print far to less for that price tag.
Yes track switch for sure would be necessary for my idea
Until today I only print mechanical part or small figurines for table top games. I just used one material. Never bothered about multi color.
The bambu system with heated build room, AMS system, easy nozzle replacement and secondary nozzle for supports and a possible multi color print every now and them just seemed so convenient
You have to know I use a prusa mini xD And all the inconvenience held me back from printing more.
If you load only 2 colors/materials, 1 per nozzle and you do not change them during the print like you print black and white, you will have loading/purging/cutting only from the start and the end. During the print will be just switch of the nozzle with some priming.
If you do change the materials/colors during the print, like blue, red, white and black. Now during the print while no change in color it will be as above. If you change the color then cut, retract, load, purge, prime, print.
For example if you print 1 cube tall 10 layers, and change color in every layer:
In the case of two colors - you will have just switch the nozzle and prime every layer.
In the case of 4 colors you will have - cut, retract, load, purge, prime, print per color every layer - which will add no benefit from the second nozzle. And will be slow like single nozzle printer or more.
Depending on the size of the model this time could be significant or just a fraction from the total time printing time.
The situation is even worse if you do use dissimilar materials like PLA and PETG. In this case it make sense to separate PETG to one and PLA to another nozzle. So here there is benefit form the second nozzle. As if the are on the same nozzle the purge will be much bigger. But then we have AUX extruder which is bowden and not all materials and nozzle sizes are supported. And even then there could be issues. Some people report it is working fine, I am reporting it is not. YMMV.
Edit:
As you can see here load and unload also could have benefit and drawbacks:
I would also mention, that even with one nozzle, printing multicolor with the AMS works great and is very acceptable regarding time for models that use color only in some areas. E.g. before the X2D when I used an X1C, I often printed single color models with some text in other colors in the first 2 or 3 layers or in the top most layers. Even today if the needed colors are already loaded all in one AMS, I don’t bother to swap them around and just print them on the left nozzle only. A few filament swaps really don’t matter that much.
Where it really hurts are those figurines with filament switches on every layer.
For me personally the true benefit of the second nozzle is that I can load different materials without any cross-contamination. That was a huge issue with the X1C. I had to purge really large volumes when printing petg with pla as support. Otherwise, some PLA would get into the PETG part and ruin layer adhesion. Even then, I never felt comfortable that there is no more PLA inside the nozzle.
Oh yes makes sens that switching beween materials is a different story when it comes to purging.
Thats great inside from both of you!
I won’t be an excessive user so I don’t mind a little wased here and there and a longer print time. I mean multi color prints aren’t usually something you need ASAP.
I have read a few threads about the printer and it seems like the oweners are very divided. Some things I think are nit picking and are only relevant for people that want to optimize every bit of it. But some have a valid point. I don’t expect perfect quality from the AUX extruder but it would be nice if it at least just works properly.
Also I am not to sure about all the restrictions from Bambu. It is closed source so it is not as customizable if there is an Issue that just bothers the ■■■■ out of me.
I have the feeling that a few units are really defective but some people think that their problems are the result of a bad design.
When I received the printer, I was curious about the limits of the AUX nozzle and printed a dual color frog with 0,2mm nozzles and 0,1mm layer height. On the first layer, there were islands of 0,6mm diameter. I didn’t expect the aux nozzle to be able to accurately deposit such tiny amounts but to my surprise, it came out perfectly.
So I’m convinced that the printer basically is very capable but there are a few faulty machines. I think the users with faulty X2D are way over represented in the forum, because probably every second user with problems posts here but only every 1/1000s user with a good machine posts about its positive experience.
I suspect what you wrote is the case, but I can see people flipping the argument and suggesting that there are a only a few “good” X2Ds out there. Whether its justified or not, after reading many X2D print quality threads, I feel lucky that mine does everything I ask it with no issues and without tinkering. My X2D is doing of good job of not making me long for some of the new multihead/hotend printers hitting the market.
That’s not how Bambu presents it on their product page (see picture), but is partially true as @Alex-vG demonstrates with his frog. What you’re saying might be one of the reasons some people are complaining about the X2D, because they expect the second nozzle to behave like the primary one.
It is suited for a multi color print so now and then if you connect one or more AMS 2 Pros to the primary nozzle, and accept changing colors will take time and can produce a lot of purge waste. If you want to crank out multi color prints like a maniac and fill Etsy with even more crap I’d take a look at the models @Eponymous mentioned. I finally went for the X2D because of the heated chamber and the second nozzle (for supports!) at a very competitive price. I also looked at other brands, and would like to see Bambu a bit more ‘open’, but as one of the biggest in business you can expect reasonable to good long term support and part availability from Bambu Lab. Prusa was just to expensive for my needs and budget.
Then I’d go for the XD2 for the reasons mentioned above, or wait until Black Friday or the launch of the X2D Pro.
Maybe they’re the early adopters owning the first productions units, personally I’d never buy the recently anounced models before Q1/2027. Another possibility is that they’re the kind of people that like to shout ‘USA!, USA!, USA!’ at each other and want to bash on Chinese products.
I simply can not believe that it is as bad as some people describe it. Seems like some issues also came from the AMS.
I think there are also a lot people buying die multi head printers and oft not making use of it. I myself was looking at them for a while and then though: wait I probably will use them only a fraction of the time.
So I’m am still sold on the X2D but let’s see what November brings.
I think people lived with single color because multicolor was difficult for many years. Now that multicolor is becoming much easier, I can’t imagine that single head/extruder printers will be around much longer. Even if your main interest is printing practical items such as car and home accessories or product enclosures that are often fine as single color, there’s still value to having a multicolor setup. My son does multicolor all the time with our X2D using both hot-ends.
Given the current evolution in the market, I’m not sure the X2D is an optimum choice as a multi-head/extruder printer, but if you are truly interested in it, I’m happy to print something of interest to you if its reasonable size, e.g., up to 150 g of filament.
There are defects, there are bad profiles, and there is a bad design!
But this are different problems not the same and they make different problems. For example bad design is how one blob can broke many parts, and then opening the extruder is like neurosurgery, and could add even more damage. And how difficult could be to clear the clog. And how easy is to get a clog. Bad design is PTFE tubes all over the place, with too small radius, and also scratching to the glass lid and the sides. Bad design is warping side panel because of the integrated heater - top selling feature of X2D! Bad design is the uncontrollable cooling and heating + not consistent above and below FANs suction point. Which causes warping in many different ways, and problems with different materials and multi material printers. Bad design is also how hard is to apply grease to the extruder tooths. And even to the rails and rods. So this are some examples for bad design. And some of them are caried over up to H2C.
Now none of the above is the problem with inconsistent extrusion results. Some of them just may add or make it worse. But it is not this bad design but bad quality assurance, bad software/FW testing and etc. Which has nothing to do with the design.
I did not tried to print with 0.2 nozzle on any of the extruders so far. But I had failures with 0.4 nozzle and the layers 0.16 and below. Aside from this I can print any kind of figurines and complex geometric stuff 24/7 and they look good. But simple qube, or something with many flat surfaces and you get the reality. You can see this from the many topics about ironing.
Aside from this limitations to the AUX extruder materials are real. But for PLA it is more than fine.
I absolutely agree on print head disassembly. It’s really stupidly complicated and with risk to damage something. Is the P2S any better in that regard?
The side panels bulging isn’t nice but more a cosmetic problem in my opinion.
I don’t have any problems with flat surfaces and haven’t heard of such problems yet. Do you have an example or a link to a thread? Would be interested to learn about it.
But you are right, it is not a perfect printer, with extruder disassembly being the most annoying downside for me. Still I’m very happy with the purchase and if I would have to choose a new printer now, it would be the X2D again. Curious if that changes with the next releases.
Hah, and all options end here? What about the one other option, like I do not care for both USA and China, live in Europe, and just go to the first shop where X2D was available, it was just around 100EUR more than P2 and I got it. Like:
But it does not really work as advertised and it is even hard to reach realiable extrusion and far away from A1 print quality?
I do not have expectations mismatch about the second nozzle. But the advertised easy and fast support printing is not true. And this is why most of the time I print same material support. Really easy and fast! And the overall quality is not good enough to care about the support traces or bottoms. This is at least so far. Of course your experience may vary.
I’m not going to start a discussion back and forth, nitpicking doesn’t provide any value to this forum. So I agree there’s room for improvement. Be aware an X2D only costs €629, you can buy 2 for the price of a new iPhone and have some money left for an AMS or some rolls of filament. Maybe we can transplant some updates once the X2D Pro launches, time will tell.
What’s easy for you can be hard for me. I don’t understand how printing one or a couple of interface layers could be slow considering a print often takes multiple hours or days. I like the AUX nozzle because, as an example, I can keep a hotend that only handles PLA and another one that only handles PETG. No cross-contamination possible!
