Erase files from Sd card
Is there a way to erase files (one at the time or in groups) from sd card , other than taking it out from the printer and putting it manually to the computer?
Hello,
yes you can do this direct on your printer one by one.
Tap and hold the file and than delete.
Or you can connect by ftp (We can now connect to FTP on the P1P) an edit an your conputer.
Cheer WR
Which printer?
Does that work on the P1P?
Thank you … will try whe I get home
it’s for x1c not sure for p1p
what about the a1 printer does it work on that???
Hi
has your question ever be answered.
you can do it in the Bambu Handy app, if you click the three bars at the top right you will see the files you sent to the printer using Send to Printer, you can then click Select and choose all the ones you want to delete. You can also click the Me icon at the bottom right of the app and go to Printing History, clicking Edit will let you select as many as you want to delete, or you can swipe left on each one for a delete icon.
