Eryone Filament? someone printed?
Hi guys,
anyone printed ERYONE Filament? I have three fresh spools silk, matte and standart pla over. i looked in the sheet and they are saying max 60mm/s printspeed.
someone tested on our bambu´s?
Yes I have printed with Eryone.
→ Printables
I printed it normally on the standard speed of the Bambu.
With 0.4 Nozzle and 0.2 Layerheight
For silk, drop your outside speeds by about 50%. This was printed using Eryone multicolor silk.
thanks guys. the silk photos looks really nice. i have rainbow silk here.
so i don´t have to drop the material in the trash and will give it a try.
I’m using Ereyone filaments without issues.
For silks in particular you should lower print speed and raise temperature (there’s a page on the Bambu wiki about this). When lowering speed, I found the best way is to edit the max volumetric speed for the filament profile and leave the other speeds in the quality profile alone. The slicer will limit speeds appropriately based on the filament chosen.
There’s a simple formula to convert mm/s to mm/s³:
SPEED_IN_MM³/S = SPEED_IN_MM/S x LAYER_HEIGHT x NOZZLE_DIAMETER
Eg, if you know the max speed for a specific filament should be 90mm/s, then calculate the max volumetric speed in mm³/s like this:
SPEED_IN_MM³/S = 90 x 0.20 x 0.4
SPEED_IN_MM³/S = 7.2
Simply put 7.2 in the filament profile and leave everything else alone.
TTYT3D rainbow filement on a p1p with default PLA settings on silent mode…
I get nice results with Eryone Silk PLA with the following settings using Softfever fork of Bambu Studio with manual calibration:
Flow ratio 1.01
Pressure advance: 0.026
Nozzle temperature: 220 °C
Max volumetric speed: 12 mm³/s
All other settings including speeds are based on the Generic PLA profile.
Bambu Labs recommends printing silk with an outside wall speed of 50. Apparently you can leave everything else in standard configuration.
OK Dude, you and me got some issues now.
My WIFE saw this and now you have to tell me where it and the Dragons came from or else. :grin:
Thanks a lot Buddy. You’re going to owe me a couple rolls of color change. And I was saving it for something else, too!
LOL
Do you need the hardened nozzle for this filament or does p1p standard nozzle work just fine?
Standard nozzle for almost everything except carbon-filled, glass-filled, and glow-in-the-dark.
I used the PLA+ High Speed Filament on my A1 and used the Generic PLA High Speed Profile. It worked like a charm…
Eryone pla+
so i read 7.2 , was going to take 6 hrs to print, surely thats not right
it sounded technical and right but yo thats really slow, trying 23
it says high speed… 12 or 7.2 is super slow speed…
i signed up just to say this
for me, on the p1s with factory 0.4 nozzle, silk prints great, matte prints great, rainbow, galaxy, dual color, just great, not so much for the petg, but pla and pla+ are just peachy
Thank you ROBBY, I confirm the impression with Eryone Silk PLA+ is now very beautiful.
Have a good day
thank you again
ERIC (reunion island)
I have used a lot of different eryone filament.
I have had all very good results with:
-Nylon
-Pla silk (gold and tri colour)
-Pla glow
-Petg-gf
-Clear pla
I definitely recommend eryone as a brand
