I am pretty new to this. I use Rhinoceros 7 to create models which I print with my Bambu Labs H2D. I am using the stanadrd 0.4mm nozzle. I print with Bambu Labs PLA Matte to minimize complexity.
In my first models I was really impressed by the precision with which parts fitted when printing parts that are supposed to be joined with some friction. By trial and error I arrived at a distance of 0.05mm gap (on each side) would do the trick. I used .stl file format when exporting the models.
I then got some issues with a model and realized this would resolve it self if I changed to .stp file format when exporting. But suddenly the models didn’t fit as snug. Admittedly, I made some misstakes as the models got more complex but I still felt unsure about tolerances. I then started to wonder, can the printer really print with as fine deatailing as 0.05mm?
I did some models with a wall thickness of 0.6mm. Having printed them I measured the thickness with a calpier and I got varying measurments. 0.6mm walls are a bit flimsy to meassure and I am not sure how accurate my digital caliper is.
An impression I get is that the modells print proportional in the sence that pieces will fitt, even though the actual dimensions may vary slightly. Any variation in size will be replicated in both parts so they will still fit. Is that your impression as well, or have I done to little testing yet?
What level of detail, i.e. how small differences, are realistically possible to print with repeatable accuracy in your experience?
Would it be worth switching to a 0.2mm nozzle to get better accuracy? Or will that just make printing harder and failours more frequent?
Have you experienced any differences with regards to accuracy with different file formats?
One thing I’ve learned about tolerances is that consistency is key. Any number of variables will affect it. Material (and condition and sometimes color) are most obvious, but there are many other factors that come into play even before shrinkage considerations.
It’s not so much that a print can resolve a 0.05mm detail per se (it can’t), more about how accurately the overall piece/model can be sliced. This will depend on the line widths being used and the wall generator (Arachne can vary the line widths, often with more accurate overall results). For example the .6mm wall with a .4mm nozzle – will that be one .6mm line or two narrower ones? The slicer typically wants at least a loop of 2 lines for a wall, which with either wall generator would be basically impossible (or very flimsy with ~.32mm lines)… and one .6mm line from a .4mm nozzle is going to be mildly challenging to keep consistent during extrusion. OTOH with a .2mm nozzle 3 lines would fit nicely (with a bit of overlap for a nice bond). Or a .6mm nozzle could squirt out a single line probably better than a .4 nozzle could (but 3 thinner walls would still be stronger).
So a .2mm nozzle may produce more accuracy in the above scenario, but that’s because it can provide more detail, not because it is more accurate per se. If scaling that .6mm wall up, say to 1.2mm, then the .2mm nozzle won’t really provide any advantage (eg. 2x 0.6 mm walls or 3x 0.4mm walls should work just as well).
As for STL (mesh) vs. STP (solid), it’s not about the format per se but about the conversion process from solid to mesh (this is called tessellation). The accuracy/detail level of this conversion is crucial. Too low a resolution and details get lost. High resolutions will result in longer slicing times (at best, crashes at worst).
The slicer itself operates entirely from meshes – when one imports a ST[E]P file into Studio it converts it to a mesh format (using the settings in the import dialog if that’s enabled).
So, it is very likely that the resolution of the mesh exported directly from CAD will be different from whatever settings are applied in Studio during STEP import/conversion. I’m not familiar with the Rhino process, so can’t comment on that (I like creating meshes from Fusion and other CAD where I can see the preview of the generated mesh – with Studio I have no idea what I’ll be getting). But in any case, consistency is key.
Close tolerances are a challenge, no doubt. Another thing to keep in mind is post-processing (sanding/etc). Personally I’ve found the most accurate holes are made by drill bits..
Keep in mind that 3D printing accuracy is based a a large number of variables. And some are already based on the file format you are using.
Some examples:
Positional accuracy of the Motion System
The actual positioning of the Nozzle
In theory the H2D can get down to 0.05mm when using the Vision Encoder
Regular Belt Tensioning and Calibration is required
Of course if your H2D would not have such an accuracy, and it would not have skew, the deviation would be in both male and female part of the interface, and therefore be similar
Data Source
STEP in itself is more accurate as STL as it describes geometrical features like cylinders as a mathematical cylinder
STL is made out of facets, and the accuracy is determined by the exporting system.
Both will end up as a facet model in the Slicer, as STEP is transformed into facets on import and depending on the fact you are still showing the translation parameters, but the default STEP import accuracy is most of the time, more accurate (3 microns and 0.5 degrees) than the settings that are used for exporting STL in many CAD systems. Unfortunately I don’t know the default settings that Rhino is using
So therefore you might have a difference in accuracy of your imported models.
Flow Rate
An incorrect flow rate can make the printed bead thinner/wider than the theoretical bead width in the slicer
Calibration can be useful here, as over-extrusion is making male object larger and female object smaller and vice versa for under-extrusion
The tolerance in the diameter of the filament allows for deviations also
Moisture
Even the slightest amount of moisture will cause the extrusion to slightly expand, biut it has a certain amount of impact, but usually the Flow Calibration takes care of that.
Excessive moisture is usually clearly visible in the quality of the part, but there is a big grey area in between.
Rubber Band effect
On circular shapes, the Rubber band effect makes geometry smaller. This is mostly visible on holes, but also on external geometry, it has a certain affect.
The latest H2D Firmware update has introduced a Circular Hole Correction that might have influenced your tighter fits.
So as you can see there are quite some factors, that are determining the accuracy of a part.
Don’t take it for granted that something that was working fine today, isn’t changing tomorrow, due to many of the above. So even taking Bambu Labs PLA Matte as the reference, doesn’t mean that moisture or production differences (size and composition) are not changing over time.
One thing I’d add is that for functional fits I usually care more about repeatability than the absolute nominal tolerance.
If a 0.05 mm clearance works once, I’d print the same male/female test several times with the same material, orientation and slicer settings and check how much the fit varies between samples.
That gives a much better idea of the usable tolerance for that specific setup than the theoretical resolution alone.
I’d also keep the print orientation identical between the test coupon and the final part, because dimensional behavior can change noticeably with orientation.
This would definitely reveal the band width of all the accumulated inaccuracy in the process.
But still a perfect fit, could not be the case anymore when you try the same part in a month, after a new batch of filament, or a Firmware update.
Specifically the latest H2D Firmware update (V1.4.0.0) has changed a lot for that matter.
Exactly, that’s a very good point.
The test would characterize the process under a specific set of conditions, but it wouldn’t guarantee that the same tolerance remains valid after changes in filament, calibration or firmware.
So for very tight functional fits, it probably makes sense to treat the tolerance test as something to revalidate when one of those variables changes.
One more effect hasn’t been mentioned yet: shrinking due to cooldown. after leaving the nozzle, it shrinks while cooling down. This is more relevant for large parts though. assume roughly 0,2% for PLA, 0,3% for PETG and more for others. If you want to compensate exactly, there are models that are dedicated for shrinkage compensation.
For really small parts, I would guess that another big impact regarding accuracy could be the seam, that might slightly bulge.
A good flow calibration is really mandatory. I recently have discovered those flow tests that are based on Archimedean chords. They are really extremely sensitive compared to the integrated test. Probably everybody knows them for years except for me
Regarding nozzle sizes: A 0,2mm definitely allows very fine details compared to a 0,4mm nozzle. I’m not sure if it really is more accurate, but I would assume it. A bigger nozzle doesn’t have much benefit in my opinion. I regularly print wider lines up to 0,8mm with a 0,4mm nozzle and it works flawlessly. If you look after faster printing, I would rather switch to a 0,4mm HF nozzle than a 0,6mm standard nozzle. It allows considerably more throughput. But even the 0,4mm standard nozzle has a lot of potential for higher speed.
A 0.05mm gap is a tight fit. At this level, even the color of the filament (same filament type and brand) may require attention because different additives affect the expansion/shrinking differently. I have found that this is particularly the case if it involves small holes.
One way of mitigation is to create a testing piece and put it in its own plate in Bambu Studio and use that to fine-tune relevant slice settings. For example, for small holes, users can try printing the test piece using different x-y hole compensation values to find a good fit before printing the complete model.
But precision has always been a challenge for friction-fit models due to the many factors involved as explained by the posts above.
Smaller test pieces can of course be very useful / practical. But one important caveat that perhaps bears mentioning specifically is that the cooling and shrinkage of a smaller part can be vastly different from a full model. By cooling I especially mean fan speeds, for example (esp. with that “fan pre-start time” a whole layer could end up being rapidly cooled because of one small overhang/bridge, like at the top of a horizontal hole). Or an easy mistake to fall into is having a quick-printing layer which is slowed down by minimum time in filament settings, not reflecting how it will print in a larger model. And as mentioned even orientation or position on the print bed can make a difference. All that just to repeat… “consistency is key.”
There are 2 basic types of “flow calibration” in Studio and IMHO it is important to distinguish them. There is basic flow rate calibration where one prints a bunch of samples and decides which surface looks best and saves that number into a custom filament profile. Then there’s “PA” calibration which BL refers to as “Flow Dynamics” which is really quite a different beast (and is perhaps unfortunately named due to potential confusion).
Sorry, not to get all pedantic about it, but I’ve seen the two being mixed up before in the forums.
It definitely is a pity, that Bambu Lab has chosen to name it “Flow Dynamics”, as it causes a lot of confusion amongst less experienced users, but also users coming from other vendors as they believe the printer automatically calculates the “Flow Rate”, when it states “Auto Flow Dynamics Calibration*.
Technically the name is not incorrect, but
Nevertheless, also PA (or FD) has influence on the dimensions of the part, in particular when the compensation is too low.
Very true, thanks for pointing that out. I was referring to flow rate calibration. I never use the term flow dynamics but only pressure advance like everybody else but BambuLab
Thank you @MaxThreeD@Gerrit@Blaster@Alex_vG@DWdesigns and @DGVeLab for taking the time to elaborate and share your thoughts and vast experience of printing with regards to small tolerances. Your thoughts and ideas are really helpful in many ways.
A part of the prototyping/testing process, the designer will have to test and make sure the result from the test piece can be applied to the whole model.
Remember that the biggest challenge is mainly due to the need to share the model with users of varying degree of knowledge, skills, and maintenance habit of printers, etc. For one’s own use, it is relatively less problematic as one can do calibrations to print out a almost perfectly fitted model.
Most of the time, for models that are to be shared, I don’t go for the “perfect” fit. I design the parts with some degree of play (looseness) to accommodate the real world variations of printing by many users and different printer setup.
