Failed Print ... unit frozen and unresponsive
Had a 10 hour job freeze ~4 hours in. Hot end kept heating and part fan kept running, but the rest of the unit was frozen. Unresponsive screen, not communicating with Studio or Handy app. Only option was to turn the power off at the switch.
I think the unit might have had an issue due to the camera and its video recording … looking at the video files, the last few entries look like gibberish, but those could have simply been “temporary” files as the video data was being written to the card.
There does not appear to be a way to disable the camera on the P1P. I plan to retry the print w/o camera, and it would be nice to simply disable it, rather than unplug it. It seems that the implementation of the camera on the P1P is still buggy (given the communication error many users report). I plan to physically disconnect the camera when I retry the print this evening. Given how fragile the connection for the camera on the control board seems, I am not too excited about doing this. I really want the print to finish, otherwise I would simply retry the print … but since I think I only have enough filament for one complete print, I’m looking for ways to improve my chances for a successful print.
So too, I had a computer with Studio open and connected to the printer (on the same WiFi), I had also queried the status of the printer with the Handy app a few hours earlier. Perhaps these connections to the printer had something to do with it freezing.
No issues with the power supply to the printer that I am aware of. I don’t know if the P1P is able to recover from a power outage like the X1 is apparently capable of.
This was the largest print, and longest duration print so far. The previous long print (the fan support from Bambu) was just fine, but was a shorter duration print of ~3 hours, where the unit froze on this long project at ~4 hours.
I had couple of power outages and clicking the play button on the screen on the p1p resumed the print for me.
Thanks for the feedback, but this wasn’t a power issue (I don’t believe). The unit was frozen (like a software glitch) - it was still on, just not printing (no movement). The nozzle head was still hot (220C) and the part fan on the head was still running. The screen was on, but dimmed, and unresponsive (clicking buttons on the screen did not wake it up).
My only recourse was to cut the power (the toggle switch on the back of the unit). When I turned it back on, clicking the play button did nothing, the printer simply stated it was “Ready to Print” meaning, I either needed to start a project from the card, or send a new project through the cloud from Studio.
Super glad to hear it does have power loss recovery!
I have had the same thing happen … looks like another software glitch.
They released this printer fast. It seems clear that the features and bugs are a work in progress at the moment.
China is having real problems right now, I am sure its impacting Bambu Labs. Considering state of the world they have done some great work…
Question? What is Handy app?
I just purchased my p1s in April 2024 and this bug has not been resolved. Just like you mentioned, my p1s just stalls with the fans and heat running. I cant imagine that this is normal operating procedure for such an expensive device.
Smartphone app to control and monitor Bambu printers:
https://bambulab.com/en/download/app
I’ve bought my p1s and only on my 2nd print it already happened. What is going on? How did you guys resolve it?
Hi, I have the same problem. The printer stops, fans, heatbed etc… continue to run but the screen on the unit is dimmed and does not respond. In the app or in Bambu Studio it is listed as offline. Just turning it off and on helps. I’ve had this happen several times in a row now. Do you have any suggestions what I can do? Thx for your feedback.
Welcome to the forum.
First thing I would try is using a different SD card. A failing SD card can do some really odd things.
Thanks for the welcome and for the tip. I’ve already changed the SD after I read that the included one can make problems. I also reset the printer because it starts after update the firmware a couple days ago.
Maybe that solve the problem. The printer is currently running again. I’ll keep you updated.
Nope. After two good prints, the same issue. After 37% it stops. Thats realy frustrating.
For me it looks like a problem with the firmware. I went back from 06.01.01.00 to 06.01.00.00 and I haven’t had any problems anymore. I opened a ticket and sent the logs to Bambu. Perhaps thats help in the future.
did you get it solved ? or still having issues ?
No recurrence for me since that failed print 18 months ago.
so what was the solution for you ?
No idea … I suspect it was a firmware issue. I had one of the first batches of P1Ps as I had preordered fall of 2022 I believe, if I can keep my years straight. I figured it was just to be expected that early on in the product cycle.
Say it one more time for those in the back. :grinning:
JonRaymand makes a good point, I probably did change out my SD card around that time, probably because when the PIP first launched, it didn’t do timelapse, and only did video, so the files were huge - so I replaced with a larger card (and a pretty nice one at that which originally saw Nintendo Switch duty).
