Failed Prints X1C
Can someone help me with my prints? In the past few weeks, I have had constant failures in my prints. I have tried multiple different types of files, and the majority of the prints have been failling/not sticking well. I have tried new print plates, new nozzles, slowing the print down, and calibrating it constantly. All have failed. I am running out of options and not sure what else needs to be done to fix it. Has anyone else had problems with this? Do you think it is the filament? What should I try next? Or is it time to get a new printer? It’s run over 5000 hours of print time.
Couple of ideas. Is the filament dry and how old is the build plate? Build plates do wear out. Also, have you cleaned the plate with soap and water?
Filament might be a bit wet that could be, the only thing that makes me think differently is that a all black print from the same ams worked well previously between 2 fails.
Different plates with variously cleaning has been used with different amounts of use in the plates.
That looks like a pretty dirty plate to me. How are you cleaning them? Are you using IPA after cleaning them as this can cause adhesion issues.
I’m using a 91% IPA. I guess I didn’t know that that could be a problem being high %
IPA is not necessarily bad for a PEI plate, but for the Cool Plate Supertack it’s disastrous as it dissolves the sticky coating.
IPA on a cloth is not really cleaning, but more dissolving and then spreading the grease over the build plate. It works usually for a while but on a very dirty plate
A PEI plate is best cleaned with the cheapest dish soap (no hand protection additives) and water. A proper rinse afterwards and dry it with a paper towel.
I’ve fixed all my adhesion problems by turning off the part fan during the first 3 layers. Dunno if this could be of any help.
Adding to the plate cleaning advice above: after washing with dish soap, avoid touching the print surface with your fingers, since skin oils bring the problem straight back. Also check that your bed temperature matches the filament (for example about 55-60 C for PLA on a textured PEI plate), and rerun first layer calibration after a nozzle swap, because a first layer that is slightly too high is a very common cause of parts not sticking. If a dry filament and a freshly washed plate still fail, try a brim on the parts that lift. Good luck!
Try a light coat of glue, it also acts as a release agent.
Needs to be the water-soluble glue stick or liquid glue. The stuff used for 3D printing. Not epoxy or solvent-style glues. The wrong glue can destroy a build plate surface.
Just a clarification. Not all glues are appropriate for 3D printing and some may not know that.
Sorry everything, turns out I’m just really dumb and didn’t think anything about wet filament. Had a massive brain fart with all of this. Thank you all for your input
