I understand, but still it is very annoying. For small parts the X1 is not really faster than my ancient Ultimaker. Why? Because it wastes so much time with doing unnecessary things such as unloading, calibration after every print and so on.
Approx. 7 mins are wasted? For 20 min prints this is a big deal!!
I think the best solution would be if the user would have a choice at the end of a turn. Respool the filament back into the AMS as you know you will anyway need another color/material or because you will not printing soon again.
If you decide against it and made it smart you could start the next print almost immediately without the additional purge waste in the beginning.
Replace the End gcode with this, no AMS unloading after print is done.
;===== machine: P1P ======================
;===== date: 20230416 =====================
; My modifications:
; Move M400 command so nozzle not sitting on print
; Remove AMS unload after print job done
G92 E0 ; zero the extruder
G1 E-0.8 F1800 ; retract
G1 Z{max_layer_z + 0.5} F900 ; lower z a little
M400 ; wait for buffer to clear
G1 X65 Y245 F12000 ; move to safe pos
G1 Y265 F3000
M991 S0 P-1 ;end smooth timelapse at safe pos
M400 S2 ;wait for last picture to be taken
G1 X65 Y245 F12000
G1 Y265 F3000
M140 S0 ; turn off bed
M106 S0 ; turn off fan
M106 P2 S0 ; turn off remote part cooling fan
M106 P3 S0 ; turn off chamber cooling fan
G1 X100 F12000 ; wipe
M104 S0 ; turn off hotend
M400 ; wait all motion done
M17 S
M17 Z0.4 ; lower z motor current to reduce impact if there is something in the bottom
{if (max_layer_z + 100.0) < 250}
G1 Z{max_layer_z + 100.0} F600
G1 Z{max_layer_z +98.0}
{else}
G1 Z250 F600
G1 Z248
{endif}
M400 P100
M17 R ; restore z current
Purge a little first. if your worried about moisture. But i live in a very humid place tropics and have no issues with it being in the tube. I will often manually load filament and leave it while i prepare other machines and stuff. This machine can be a total procrastinator screwing around winding unwinding cutting, purging, “calibrating” levelling, scanning, etc etc etc. Any amount of time saved and material not wasted is a benefit to me honestly.
Yes please, do this optional.
Same for me. Printing with the same filament most of the time.
I have been searching for this option some time and couldnt belive that is not implemented.
The retraction of the filament into the AMS is defined in the g-code in the Printer setting → Machine G-code → Machine end G-code.
There is a section which begins with a comment: ‘;pull back filament to AMS’
; pull back filament to AMS
M620 S255 ; **begin tool change**
G1 X20 Y50 F12000 ; **move and cut filament**
G1 Y-3
T255 ; ** do tool change**
G1 X65 F12000 ; **move over poop chute**
G1 Y265
M621 S255 ; **end tool change**
2 Asterix comments are my understanding for what happens, without any warranty.
If you want, you can try this:
We have an option for bed leveling which allows me to choose when it’s appropriate, such as when using materials with different bed temps. While there are great points above that the default option should be that it retracts to prevent moisture sensitive materials from deteriorating, this option would allow us to save time and material in the very common situation where we are printing consistently with the same material. Making this a checkbox option feeds is consistent with allowing more advanced users to determine the workflow that is best for their situation.
Here is a guide from the bambulab wiki, so this might be the (officially) best way.
If you want to do it with gcode, i would suggest to check that your solution matches with this guide.
(Ill think about it but i dont want to tinker and just focus in my prints and change the color more or less often to mind that for every print.)
Please make this an option at the start of the print when sending it to the printer. I, like many others, run a test print and then print another after tweaking. If the concern about jams and moisture is great enough, then perhaps put a timeout after printing finishes and no new print is started. The system would unload automatically after 30-60 minutes.
I replaced the “; pull back filament to AMS” section with your code to parametrize it with 1 or 0 in the notes section however I keep getting this error upon slicing:
Failed to generate g-code
Machine_end_gcode parsing error at line 18: Not a variable name {if notes== “0”}
Just veryfied it:
For Orcaslicer: {if notes== “1”}
for Bambuslicer: {if process_notes== “1”}
Sorry for the inconvenience, but I only use Orcaslicer.
If you hoover with the mouse over the field, you get a short explanation and important: a ‘parameter name’.
This parameter name you can use in the g-code.
I only use one spool through the AMS (same applies to external spool setups), and the automatic unload after each print is unnecessary, wastes time, and sometimes leads to filament detection issues.
I suggest adding a checkbox in the AMS page of the printer firmware, and maybe also in Bambu Studio:
[ ] Unload filament at end of print (Unchecked by default)
This would let users with simple setups avoid unnecessary unload/reload cycles.
Ok so first: an option in the software would be amazing, bambuu need to add it.
Second: The wiki for the A1 serie suggest a second change to avoid material waste which is to also remove the flushing of the old material in the g-code start. But it’s not showing the same code as I have for my A1 mini, for that second step, so I’m not sure what’s the g-code that needs to be commented out? I also asked on reddit, but no one was able to answer
