[Feature Request] Reorder Plates in a project
When working with several build plates in a project, it would be really useful to be able to re-order them.
The Problem
Here’s a project with six plates. I’d love to be able to move Plate 6 above Plate 2…but to do that now I have to copy-and-paste the plate contents around and rename things. It’s a bit janky!
The Solution
Ideally this would be achieved by dragging the item in the tree view, just like we can do with objects within a plate.
I should be able to collapse the tree then grab Plate 6 and drag it between Plate 1 and Plate 2 (below ‘Assembly’).
For Bonus Points…
Adding a ‘Collapse to Plates’ option to that tree view would make my life immeasurably better :slight_smile:
I’ll second that. These would be two very quality of life improvements. The collapse to plates feature alone would definitely help out a lot. When one is using the printer to print one model at a time, this may not seem like much of a big deal. But try printing an entire Bill of Material and one can see that this quickly gets out of control and one winds up in scrolling hell trying to visualize the build tree.
Here’s just one example. At least they added the search by part feature but it’s limited.
I have been searching for this feature as well. Please add this ability to re order plates in a project!!
Granted there are a couple of duplicate plates in this image but I figure that since there are about 6 other plates to go along with this build that would have been in this array if I hadn’t given up, I think this represents a need for the ability to zoom all and the ability to reorder.
I’d like to put another vote in for this feature request - it’d be very-very handy for anything more than a couple of plates.
Another vote for this, please.
Another vote for this. Would be super helpful
I agree, this is a surprising oversight.
As is the inability to reorder filaments in the side panel.
If I wish to tidy out some filaments, I have to manually change them as I can’t reorder them. I can’t delete one specifically, it has to be the last one that gets removed!
These are basic software features.
Plus, all we are talking about is changing array element positions, most programming languages provide this as a single line of code. The UI interaction code is minimal.
This is a MUST. Quite surprising that this wasn’t a feature from inception.
I agree with that. It’s still inconvenient that you can’t sort the discs.
A vote here also - Would be Wonderfull :slight_smile:
This feature would really help to elevate Bambu Studio above the competition. I vote for this feature too!
+1 We need to be able to reorganize the build plates from the Object list at a minimum. Thank you.
Another vote for rearranging and or collapsing/expanding plates
Another vote for rearranging plates. I would also like a way to make them visible/invisible (probably with a checkbox in the tree)
I vote for this too, including collapsing/ expanding features!
Do you mean Printable and unprintable on a global basis, or actually hiding a plate from the layout altogether. I’d be in favor of the first, but making it no longer viewable in the Plates layout, I think that has the potential to screw up some peoples day.
I mean to hide the plate from the layout, but maybe this is not the right way to go about it. I certainly understand your concern. My problem that I would like to solve is that I find it sometimes hard to work on a single plate, when other plates are obscuring my view. Maybe a way to view a single plate vs seeing all, like a toggle, is a better way to go at it.
Making an object unprintable is sometimes quite handy, but I’m not sure what the use would be of making an entire plate unprintable. I could just choose not to print the plate…
+1 for the feature rearranging plates and collapsing/expanding all plates with one click. And as @MalcTheOracle also said, the same feature could be added to the filaments.
Requesting this feature also. Seems it should be easy to do.
