I took my buffer off, decided disassembly was not the right first step, reinstalled it and then just pulled hard, back towards the AMS. Didn’t move, at first. I think I might have pushed it forward and it budged, and then when I pulled back I met some initial resistance and it released. Been working fine on every print since and it’s been getting a workout with lots of filament switches. Maybe there was a burr or some plastic flashing that made it stick and I “removed” it in the process of forcing it past the obstruction while freeing it up. It happened maybe in the first 100 hours of use and I’m pushing more than 10x that now. Hasn’t reoccurred.
Woot! its clear. I took it off, uncoupled and the CF pulled right out. Now to figure out why the reloaded spools in the AMS have question marks. D: - Forgotten Spool Info more here.
Nice. I think i resonded to you on another thread. Looks like you already figured it out though.
Took the glass lid off and its not jamming. It seems to have to with the friction of the PLA-CF and the bend radius on the hotend ptfe.
Any updates having similar issues.
I have a new machine and have the same issue, I found the easiest way was to remove the PTFE tube at the join and help it back, its not a jam just friction but obviously its a pain as you need to be about when it unloads. After reloading and loading (mistake on a print) it is not fixed but slowly getting easier to unload. As I type its starting to unload automatically again (8 x loads and unloads)
Same issue here, i did open a ticket, hopefully Bambulab is coming with a future proof fix…
Hello,
I have the same problem on our 4 printer at work, this is a huge problem for us because slowling down our intensive use of the P1S printers with AMS.
The only way we found is to disconnect and reconnect the PTFE coupling at the back of the printer, just pushing a bit the filament is making the printer restart but this is a big problem. Any long term solution found ?
Have you already replaced all of the PTFE tubes? They do wear out and it sounds like you use them a lot.
thanks @JonRaymond , one of the printr has less than 2 weeks and we do have the same problem on all printers… it really looks like the buffer is blocking the filament when the ams is retracting, the two parts of the buffer making a kind of double wedge assembly blocking the wire
Some people that swapped the buffer with the hub does not have this problem anymore.
Sorry maybe a stupid question : what is the hub ?
I have had that issue since new. I have to pull on the right PFE tube on the buffer to release the filament. Then its ok for a while so I haven’t been able to figure it out. The extruder isn’t clogged and I don’t know enough about the buffer or what makes it work. Various brands and types of filament it can happen to or not.
I guess you have pulled the tube out and made sure the tube was cut square.
After your satisfied it’s square then put the tube back in, make sure its all the way in. If you don’t the filament will catch the edge that is not pushed in all the way.
I had a similar issue that seemed to be fixed when I straightened the tube path into the buffer from the moving side (the right side)
It also cleared up when I unlocked the tube feeding into the printer and released the tension
I made the model AMS Buffer Tube Guide/Release to fix this, and I haven’t had a problem like this since I printed and installed it. Search or click BABufferGuide to find it.
I’ve similar issues. If I remove the filament buffer from the printer and just let it hang freely the issue goes away and everything works as it should. But if I attach the filament buffer to the back of the printer the filament will eventually get stuck and the AMS cannot load/unload the filament. For now I’m just letting the filament buffer hang loose.
I had to do the same thing until i got another AMS. Then with the new buffer I mounted it normal and has been perfect since.
