Filament calibration
What is the proper calibration sequence guys? Do the k value calibration then flow and then PA? Or different sequence?
I doubt it matters for most materials, but you should do flow calibration first and then PA.
And unless you are printing something exotic or foaming, like LW-PLA, flow calibration is mostly pointless and you are good if you just stick to the defaults for that filament type. Diameter of the filament can vary by quite a bit and thus the flow differs by a few % as well (as much as ±5% which means a 10% spread), so unless you confirm that you are calibrating at the average of that filament, it’s better to just not touch it at all…
The same mostly goes for PA, I just use 0.02 for most PLA. Some I have calibrated were a bit off (like 0.023), but that would be barely noticeable. PETG/CPE, Nylon and stuff like that is a bit more tricky, but for regular PETG I just use 0.04 without issues. YMMV.
Of course if you are printing engineering parts or high volume with certain filament, it’s worth calibrating, but I don’t see the need to calibrate every single color.
Thanks. I’ve been having tons of first layer issues and support said to do calibration. This is both on my p1p and p1s, but it was never an issue before :rage:
