Hi guys,
I have found my AMS in a weird state a number of times now, first on slot 2, but now in slot 3.
I’ll go to start a print and notice that a slot shows no filament, where I clearly have filament.
I go to investigate and find the filament between the spool and feeder clearly pulled super tight.
If I try to rotate the spool at all, it is clear that the rollers are locked up.
If I try to move the filament in the feeder, it springs into action trying to tug on the filament.
If I release the feeder and pull the filament out of it, it is parked on a totally stripped out section of filament (the reason it shows no filament present), and has about 205mm of good filament beyond the feeder.
If I break off the damaged section and feed it back in, it successfully scans and loads filament data.
Since this doesn’t happen during a print, I have to assume it is an issue when pulling back the filament to unload after a print.
Any ideas?
