Firmware 01.08.50.18
Updated to the latest firmware 01.08.50.18 on my X1Cs and two of my printers came up with the same error . Tried re-slicing, changed back to factory settings … The solution was to re-format the micro SD card!
Screenshot 2025-04-22 095343
we’ve all had to roll back
Aucun souci pour moi une impression de 5 heures sans souci
Same to me. I have opened ticket. They wrote that I have wrong SD card. But g-codes in internal memory not works too. Only banshee and refill rolls works.
Having upgraded only this morning, when i paused the print job after layer 1 was printed just before it did an inspection, the job paused, but the display didn’t change either on the X1C or in the clients. This meant i was unable to resume the job. Stop was my only option.
Another issue, printer reported I needed to format the SD card so I formatted with the printer and then the above error came back. Removed the SD card and formatted it on my PC and it solved the problem. So the printer format seems to be a problem
mine is printing fine havent had any errors
