First Layer Problems
Hi,
i have the P1P since friday last week. Now I niticed some issues with the first layer. Starting with bad athesion but this is maybe another topic.
What i figured out is that the first layer should be 0.2mm as given from the slicer.
After some teestprints and meassuerement i noticed the layer ist 0.5 to 0.8 mm to high.
Maybe this also causes bad athesion!?
The first and second picture shows 0.2mm layer set. The 3rd is 2 layer with 0.2mm set and the last picture is with 0.3mm layer set.
Does anyone know how to handle this?
So sieht das bei mir auch aus. Ich werden den Bambulab für schnelle Drucke verwenden und meinen Prusa für die, die exakt werden müssen. Gut, dass ich den Prusa nicht gleich verkauft habe.
Use isopropyl alcohol 99% to clean the bed if it’s still not sticking and use glue sticks they are your best friend. I wouldn’t worry about a deviation of half a millimeter. Print a couple 20 mm cubes use some calipers and they should be very very close.
Musst dich halt mal mit dem Slicer befassen dann bekommst auch exakte Drucke hin. Auch wenn alle sagen perfekte Prints out of the Box, man muss immer etwas feintunning machen.
