They actually do use indicating beads, the orange ones, just not a lot of them. I’ve recycled their packs several times, just not in the original, melt on contact with warm air, bags.
Wow, that’s amazing, it’s great that you bothered to check it out. But my problem isn’t the bottom or top, but the sides. The first bottom layers are even, and only the top few are starting to spread outward. Unfortunately, the colors are the ones I got with the printer. The filament dryer hasn’t arrived yet, so I haven’t unpacked the others I bought separately.
Mine turned out just like the one in the attached photo. I knew there would be a problem with the quality of the top layer due to the many fine details, but I didn’t expect the top layers to expand. This print was just a test to learn the settings, but from what I can see, I still have a long way to go. For such small details, I bought a 0.2 nozzle.
I haven’t experienced that.
That makes sense.
I am printing one with red and white so my eyes don’t screw up.
If there are any other tests or photo angles you want me to try, let me know. I have four P1S printers available to run tests if you wish.
If you see the photos in the first post, you’ll know what I’m talking about. I don’t know if it’s worth wasting time and filament on what I printed as a test.
I’ll try to dry the filament thoroughly first and then see how it turns out, whether the top layers will be expanded.
I haven’t experienced what you have. I haven’t ever on any Bambu Lab printer (I have six).
Close the door and try it again,
It’s too late today, I’m tired, and I have to get up for work tomorrow. Maybe I’ll try printing it again after work.
I’d check the top-layer flow and cooling first. Since the bulge only appears in the last few layers, it may be caused by heat building up near the top rather than ironing. A slower outer-wall speed and more cooling could help keep the walls straight.
Hi, I just got back from work. At first glance, the side of the keychain looks much better than mine, but could you take a similar photo from the same perspective as in my first post? I want to be able to compare them 1:1.
Maybe the lack of a cleaning tower causes this effect, the printer applies layer after layer without a break and the filament does not have time to cool down.
This was my first day with a 3D printer, so as you can see, I have no experience with this machine. My friend sent me this keychain design, so I decided to print it. Since I received two colors with the printer, I decided to use them, so it looks like this. From what I can see, the cooling is set in the filament profile. Well, I haven’t messed with that yet, but it would be great if you could provide some tips.
Too much flow IMO. This could also be moisture producing excess ooze flow. But it’s bulging on all sides of the top, starting at the layers which get fully filled in. Since this is a small object you could maybe test by just dropping flow by 5% and rerunning, as a vibe check.
It also might be interesting to see which color gets printed first within each layer when it starts going multicolor. I would prefer the Green to go first [outline] since that should set up the hard outside edge, and excess flow then goes up instead of out. And if excess flow happens, decrease flow ![]()
I just finished a print with slightly different settings. The filament is dry, so moisture is out of the question. Maybe I’m being too pedantic and expecting miracles, but this latest print, despite reducing the speed and adding a cleaning tower, turned out exactly the same as the previous one. I’m uploading the settings file and photos of the sidewall from a microscope.
Keychain_Lenka_test.3mf (2,1 MB)
Very confident from those photos that flow is your problem, you have too much
Every layer that is filled with “solid infill” aka “# top/bottom layers” is stretched out, and the areas with infill [that has airspace to catch overextrusion] is not stretched out. You can confirm this “solidness” in the slicer preview
Do the flow test or reduce it.
I would also recommend a better infill type for small areas. If you preview how crosshatch generates in such a small design, it never crosses nor hatches. Maybe cooling shrinking is contributing to the problem too, and in that case, something more isotropic is better. I think flow is the more relevant setting though
Exactly as you indicated, the green layer is the top of the keychain. I’ll run the flow test again and see if anything changes.
Currently, I have the flow rate set to 0.98. If the test results are the same, what value would you suggest setting?
Another setting that might change the result is to force the green first
At defaults, this is how that first green layer gets printed
If orange is overextruding, it has overflowed over it’s boundary already, now when green is coming in to draw the outline, it has even less space, and gets pushed out sideways.
If you reverse the filament print order
It begins with the outline, on a pristine layer with nothing else printed there. This “barrier” should force it to squeeze orange’s overflow upwards in Z, not in lateral XY
edit: this is a long way of still saying that I think your examples have too much flow
I use Bambu Studio, and I have it set to print the inner wall first, then the outer wall. Should I reverse it now? The MalcTheOracle who printed this keychain using my settings says his walls are straight. He printed on the same printer as mine. Of course, there could be a million other factors, but I’m trying to understand this because I’m very much a beginner.
Inner/outer isn’t what im referring to. When you have 2+ filaments, each layer has 2 iterations, and each filament gets its own inner walls, outer wall, etc. Check it out in the preview pane, using the “line type” visualizer.
I’d reduce flow. The informed way would be to run the test. ( Flow Rate Calibration | Bambu Lab Wiki ) The vibes based on photos way would be to reduce it with some significance, say to 0.94, and try again. Every roll is different, despite what marketing likes to say ![]()
I have taken a shot at both ends while the edges are clearly visible, as I notice you used that lower down to highlight what you are experiencing.
If this isn’t what you need, I will do another way.
My tremors make things hard, but I will do what I can.
These were printed without changing anything in your 3MF except the red/white one had a prime tower and different colours of the same filament.
