Get "failed to connect to server" message--nothing works to fix it
You can find here a list of tcp ports used by Bambu printer:
no link because it’s forbiden
As I use a firewall, unless I config it accordingly, the only way for see my printer connected is to use my wifi phone access for both my PC and the printer and then… it’s ok.
Much more easy and professional to get an ethernet port in the printer and direct LAN access.
Hi, got my new p1s today and it got an ip from my wlan. My phone in the same wlan works fine with the printer. i can send printjobs and see the camera … But i cant connect with bambustudio on my pc (same LAN) to my printer. the printer is listed under my devices, when i hover with the mouse over the printer it says online. But when i click on the printer name it shows nothing under status, sd card … And on the left top corner theres an orange sign no connection to the server.
I turnt off my antivirus, the firewall and my pihole. nothings seems to work.
Any advice?
And logging off and on won’t fix it?
Edit: Found the Problem. My IP Adress was in a 169. … Range. Don’t know why and how it changed. In the Win 11 Settings my fixed ip (192…)was correct but on the console, ipconfig showed a 169. adress. After applying a fixed IP again, the concole showed the right Adress and the Server connection was ok.
I just got my PS1, and I am brand new to 3D printing. I can print from my phone just fine but I cannot get the server to connect no matter what I do. I tried a few things here like logging in and out a few times and reconnecting the printer. I don’t have a hotspot on my phone to try. But this is super frustrating and i dont know what to do at this point.
Welcome to the forum.
If you can print from your phone, your printer should be bound correctly.
Are you sure you have logged into the same account in Bambu Studio?
Yes. And I am sure, because I did not at first lol but I am signed into the same accounts on both laptop, phone, and printer.
If you have Windows Firewall on the laptop you can try turning it off completely and see if that changes anything.
I am going to check my IP address like the comment above my initial post. But on another note, on the two prints I have attempted the filament has required me to manual pull it out front the back tube as it couldn’t retract back into the AMS…. okay I did that. After the second time, it kept giving me this error,
“Please pull out the filament on the spool holder. If this message persists, please check to see if there is filament broken in the extruder.
(Connect PTFE tube if you are about to use AMS)”
I have taken all filament out and reloaded it, as well as taken the entire extruder apart and changed the hotend to be safe. But I am still getting the same error and it refuses to print at all now.
Is it possible that the PTFE tubes have some tight bends between the AMS and the print head? Sometimes even the slightest curve will cause enough friction to give that error.
I am about to lose my damn mind. Last night it finally decided to print and did great during the whole 14 hour print session. It even retracted the filament, yay! Then I did a quick 10 minute print right after that, but it couldn’t retract the filament again and now I am fighting the same code. I replaced the PTFE tube inside that connects to the extruder. This thing is only 3 days old. I am not using any external spools, only the AMS. I have taken the extruder apart twice. I am at a loss.
Well I just completely disconnected the AMS and doing an external spool and all works great. No issues at all. But how do I do multiple colors with external spools?
Same here, no remedies… Tried everything…
Not… Your external spool is manual so not interacting with your A(utomatic)MS
I have been watching the printer to pause it in time to switch colors when needed, simply stuff like for a top lay of text. Everything works great this way. The AMS isn’t even a week old so if I cannot get it to work in the next few days I am returning this thing. So disappointed.
Sorry I don’t get it.
Ams has 4 colors and you can choose colors on any moment you want you do t need the external spool
In the slicer on the tuigt side there a green line.
Click on there and you can pause or change filament
My AMS isn’t working properly. It won’t retract filament and now keeps saying there is Filament broken inside it but I can’t find it anywhere.
It’s brand new. I dont know why it is giving me so much trouble.
This started happening to me 2 weeks ago. I’m using MAC OS 15.3.1, Bambu Studio 1.10.02.28 and the current one before that. Router/Printer hasn’t been moved or settings changed. Bambu Handy works fine.
WOW - this just solved my ‘extremely frustrating’ issue! I received my new H2D yesterday and everything was handshaking just fine. Rebooted by laptop this morning and the ‘failed to connect to server’ message appeared. Try everything suggested; rebooting, logging out/back in, etc. Nothing worked. Made my cell phone a hotspot and then connected by laptop to it and boom, problem solved. Much obliged for the solution my friend!
i found we had to many printers and phones running in the house , i upgraded our server and all connection problems solved
I just got my p2s yesterday and test printed a scraper with the bambu handy app. Then tried using my laptop to test print some legos and found out that my printer cannot be connected to the server depsite turning off firewall and uninstalled/installing the bambu studio driver. Any suggestion/advice on this?
I have similar error I’m using IOS No changes in my network/firewall/hardware/software. Verified everything is connected on the printer and the software, but Bambu software will not connect to the server to print.
