Getting small blobs on my first layer
Since the last update, a lot of my prints have been failing. I notice that on my first layer I am getting extra filament or blobs that it is causing the second layer to hit the model and detach the print. I have try cleaning the nozzle and even chaining it for a new one. I have also reset it to factory and change from AMS to the external filament
At this moment I ran out of ideas of how to fix this problem. I believe the issue is that the nozzle drops extra filament here and there and I have also notice that it drops even after the job finishes.
Any idea why this is happening?
I have the same problem. I have just write bambu support.
I will write you with his answer.
@German Did you ever receive an answer and a fix to the issue?
I have same issue, anyone dignify you with an answer?
I also seem to be having more print issues like since the last update a couple of days ago. I’ve tried doing a cold pull, and cleaning the nozzle without any luck so far.
I have 2 p1p and both updated with the latest firmware… one machine is having the adhesion and blob issue using the original textured plate that comes with it but my second machine seems fine but it is using the new bambulab gold color textured plate. that is absolutely fine…
am frustrated as i have nearly 80% fail adhesion on the first machine
I am having this issue (2025) - but I don’t know if it’s the printer or the PETG filament is not dry enough
