H2D Firmware V01.04.15.00 beta?
@SupportAssistant
I just received this beta version unannounced on my H2D.
Any information about the content of this update?
wild guess: z-hop knocking noises of motors being addressed
My guess is same as H2C essentially no improvement
Same - been looking for patch notes or something before updating
I am in the middle of a print so it has to wait until morning anyway
I would guess that there is something changed. I found it already weird that the H2C didn’t have any patch notes.
If there is nothing new, at least there is something fixed.
The Z-axis knocking might have been fixed, but I haven’t had that issue in the first place.
So I don’t know where to look for, other than regular use and see, nothing weird is happening.
Support pushed this one “H2C 01.02.50.00” to me a few days early, stating it should fix AP Board issues (where you have to short the board to boot). Time will tell.
It might contain the same fix.
Also the Z-axis knocking is an option, or both.
Still weird, since normally the beta’s come with some release notes.
Very Informative here as well
I must say, I am running the beta now for a while, and have seen no issues so far.
I can understand that there are no new features, but the least I would expect to get a list of fixed issues.
Same, not a fan of just willy nilly updating - let me be the guinea pig mentality…
I mean this is beta, so there are risks, but not even knowing what risk there is hits a bit different…
I’m rolling back.
Installed this and the printer went stupid (I’d use the other word but it’s probably banned.)
Loses it’s position and crashes into the LR filament cutter on filament change. Knocked the cutter gear teeth off, I fixed it once and tried to run the print again and it still acts up. The first print layer shifted and I thought perhaps a fluke as this printer has been rock solid since day 1 (June 26).
Full print calibrations were run after the update including high heat bed leveling.
Ridiculous.
I’m not taking a chance with the same on my H2C so that’s also downgrading right now.
So far I haven’t had any issues with the beta version.
Did you restart your printer and run the calibration procedures?
Of course.
Power cycled, ran full print calibrations including high heat bed leveling and High Motion accuracy with the vision encoder plate. Always do. Only thing I didn’t run is high precision nozzle offset as I didn’t want to unload the ASA I had queued up and load PLA.
Just got back on it to check so will know soon enough that the rollback fixed it.
Well, thinking about the firmware update again in relation to the announcement of multi size nozzle printing, this beta might just remove the restriction for multi-size nozzles.
I expect a new version of Bambu Studio to be launched with the H3C to support multi-nozzle sizes in the slicer.
OK, so a little more digging and I think now it’s not the recent firmware update, but the dual nozzle/layer height time-lapse bug I tripped across. Re-installed the beta firmware, running all calibrations, and running the precision nozzle offset this time as well. I normally don’t even have time-lapse turned on the print panel but somehow missed that it was on. This particular print WAS 2 color face down for a few layers. Trying to print a code for my H2C to read the Biqu glacier plate.
It’s not so much the shift to force a 'smooth" timelapse under these conditions that is concerning, but causing the toolhead to slam into the frame and the loss of position sensing when it happens.
How does stuff like this make it out of QA? SMH.
RE: Nozzles. Another “nozzle” peek shown by Bambu it’s now clear those of us that invested in extra vortek nozzles are left holding the bag. Feels like a bad stock buy. I won’t go into it here, but I have a long winded post elsewhere about having to tune for the different nozzle flow rates - something the firmware should be doing for us…
FWIW, the latest beta Studio still doesn’t have multi-size nozzle support. The firmware might be ready, but studio isn’t yet.
I just said that.
I guess Bambu is just releasing updates without any release notes or community announcements?
01.04.20 notice for the H2D this morning.
I installed that one also last evening. I guess they are prepping the machines for multi-size nozzle printing, as the multi-size supporting release of Bambu Studio is expected tomorrow.
