i dont see how this can be… it says 4 ams pro 2… and 8 ams ht… wich makes 12, x2 will give you 24… so every ams would be 2 slots only
Edit: Please see my larger post below. Includes all information and in much better formatting for reading.
AMS HT uses RFID to auto-match drying settings for Bambu official filaments no manual input needed
The AMS HT will be compatible with all Bambu Lab products.
AMS HT compatibility with X1 and P1 printers will be added through an OTA update by the end of April.
AMS HT compatibility with A1 and A1 mini printers will be added through an OTA update in Q3 2025.
X1 and P1 series printers support up to 4 AMS HT connections at the same time.
H2D and X/P/A series printers are connected to AMS HT and use drying function. Each AMS HT requires an external 220V power supply for drying It is not supported to draw power from the printer for drying (The power adapter is pre-included with the product package).
You would have 4x AMS pro which is 16 total. Then you have 8 one slot to make 24. Plus one external spool for the 25th
lol
I smell bs. This has to be fake
Pulled directly from source as well, trying to find any relevant info I can
ahh makes sense yes we will see hopefully this would make sense and be great imo
I guess this means we will need 9 plug sockets to run the printer at maximum capacity. That might even need to be over multiple circuits
Maybe they will do a combo power brick for the AMS HT to chain them.
i think it has fleme detection mybe
does it has lidar
Why ? when they have the ams lite specific for those printers
can u get the specs to the ams ht (ams for the h2d)
The all-new 2nd-generation AMS 2 pro, features more powerful feeding motors that significantly boost filamentfeeding efficiency, accelerating multi-color and multimaterial printing.Even better, the AMS 2 pro introduces afilament drying function with active air vent on a fully sealedsystem, greatly enhancing drying efficiency and maintaining optimal filament conditions for extended periods.
“Maximize material efficiency minimize waste”
“Dry Filament Quickly and Intelligently”
“Powerful Bambu permanent magnet synchronous servo motor sped-up the filament feeding by 60”
“Engineered To Better Dry Use High-performance Filaments
“Use High-performance Filaments”
“Faster multi-color printing”
“Active Air Vent”
“Fast filament drying air-tight filament storage”
“24-Colors”
“Serial connect up to 4 AMS 2 Pro 8 AMS HT total of 24 filaments”
“65 Drying”
“Brushless Motor”
“60% faster feeding speed”
“Automated venting facilitates dehumidification during drying and airtight sealing for weeks of quality printing”
“Auto-rotate Drying”
“During the drying process the filament spools rotate automatically to provide more even drying”
“RFID Sync”
“AMS 2 Pro uses RFID to auto-match drying settings for Bambu official filaments no manual input needed”
“Speed Up! Faster Multi-material Printing!”
“Average 10min saved for 100 filament changes”
“Easy-access Guide Rails”:"Easy-access Filament Tube”
“See-through filament guide rails and a quick-release feeding mechanism make removing stuck filament quicker and easier”
“Ceramic Inlet”
“Accurate Temp Sensor”
“Ceramic filament inlet offering indestructible durability”
“Accurate temperature and humidity sensor for clearer readings”
“The AMS 2 Pro is compatible with all Bambu Labs”
Trying to see if there’s similar posted for it, there’s a lot of text and a lot of duplicated text to clean through
post your source, [25 chairs]
It’s literally the Bambu accessory webpage, directly from Bambu that was posted in the start of this whole thread.
AMS 2 pro on the A1 and A1 mini is intresting
its not even april 1st yet.
Has anybody else verified this? Im on my phone.
You can already do that. I used Fiberlogy’s BVOH to great effect in 2023 with my X1 & AMS. It just needs to be really dry (it’ll suck moisture out of the AMS well before any silica).
But PETG for PLA (and vice versa) usually get’s the job done at a much lower price.
Open the accessory page link provided above by Nisparks
Press F12, view HTML, search for items like AMS HT, H2D, AMS Pro, congrats, you’re not viewing the source directly from Bambu.
