How would they know what to fix?
You know they can read these threads that contain where the information is leaking from right?
Yeah, obviously, but that doesnât mean the night IT shift would be reading them within a few minutes of release to be able to take stuff down.
Zammer, FYI the specs listed in this thread came directly from the Bambu store accessories page. If the information is no longer there, then it was removed by Bambu.
I was just about to say that bambu is finally active on these forums, but for the wrong reasonâŠ
Check your browser if itâs not showing up. Hot take but it could be that. I use Firefox mainly on my personal computer.
Bambu Lab H2D
Overview
Rethink Personal Manufacturing
Dual-Nozzle Evolving 3D Printing
Explore Dual-Nozzle Capabilities Flexible and rigid, low cost and exotic materials in one print.
Multi-material Printing Combine flexible and rigid materials in a single print to create impressive interlocking structures and innovative designs beyond traditional manufacturing. Pairing high-performance materials with standard ones further reduces costs and boosts material efficiency by using premium materials only where necessary.
Dedicated Support Material Perfect supports with minimal waste, purging and reloading. Print with support is no longer a headache. With H2Dâs dual-nozzle setup, one nozzle can be reserved for dedicated support material, allowing secured print and perfect support interface.
Efficient Multi-color Printing Fast and efficient multi-color printing. Dual-nozzle printing reduces purge cycles in multi-color prints. H2Dâs smart algorithms calculate optimal filament use, maximizing dual-nozzle efficiency to save time and materials.
All-in-one Solution For Personal Manufacturing
- Laser - 10W and 40W 455nm Laser for engraving & cutting
- Digital Cutting - Precise cutting and foiling with a variety of versatile blades
- Pen Drawing - Drawing and writing
Live Spatial Alignment
What-You-See-Is-What-You-Get The H2Dâs BirdsEye camera, combined with computer vision algorithms, delivers top-view alignment accuracy up to 0.3mm. This advanced spatial alignment allows users to place the tool path at the right position on the material â truly âwhat-you-see-is-what-you-get.â*
Auto Arrangement Maximize material efficiency, minimize waste. Leveraging real-time images from the BirdsEye camera, Bambu Suite can automatically arrange your project to optimize material usage. This feature ensures minimal waste while helping you get the most out of every project.
Donât Worry About Safety â Weâve Got You Covered
Laser Safety Windows Operate and monitor laser projects safely without the need for goggles, thanks to our safety windows.
Air Purifier An optional air purifier ensures clean air, even during indoor laser operations.*
Donât Worry About the Settings â Weâve Got It Covered
Material CodeSync Effortlessly sync settings with no manual input. The H2D can automatically scan the QR code on your material to load the perfect preset.*
Full-auto Calibration A single tap initiates automated laser focus verification and material recognition, eliminating manual module adjustments while enabling precise configuration of material thickness, and positioning.
Air Assist Improve surface quality by directing high-speed air to cool the laser path, ensuring cleaner and more precise results.
Contact-less 3D Mesh* Advanced optical height measurement creates a detailed 3D mesh without physical contact, enabling precise laser work on curved surfaces.
Go Big, Go Fast, Go Precise
Our Secret Weapon: Vision Encoder 50”m ultra-fine motion accuracy*
An ultra-accurate vision encoder plate, combined with 5”m resolution optical measurements to track and correct toolhead motion, enables the H2D to achieve consistent and reliable distance-independent 50Όm motion accuracy across the entire workspace, one order of magnitude better than its predecessor.
King-size Work Zone
Break free from size constraints With a print volume up to 350mmĂ320mmĂ325mm*, creating large-scale projects has never been easier! From laser engraving on sizable objects to printing oversized models, the expanded capacity empowers you to bring even your most ambitious ideas to life.
350°C Hotend & 65°C Chamber Heating
Unleash the full potential of high-performance materials Equipped with 65°C active chamber heating and a high-temperature hotend reaching up to 350°C, the H2D delivers precise closed-loop temperature control. This advanced system effectively eliminates warping and deformation in high-performance materials, ensuring superior layer bonding and maximizing their full potential.
REAL High-Flow Hotend*
Consistently print at 600mm/s with ease The H2Dâs purpose-built high-flow hotend ensures reliable, high-speed printing at 600mm/s. Designed for consistent performance, it eliminates mid-print speed restrictions, enabling uninterrupted high-speed printing regardless of the print size or complexity.
DynaSense Extruder
Intelligent sensing for precise extrusion control Bambu Labâs proprietary PMSM servo architecture establishes an intelligent extrusion governance system. It executes 20KHz Torque/Resistance and position sampling to dynamically modulate electromagnetic torque vectors. Reducing VFA and detecting filament grinding and clogging.
A Smarter, Safer Experience
Nozzle Camera
Monitor extrusion at the nozzle tip The H2D features an AI-backed nozzle camera with macro lens. This intelligent monitoring system continuously tracks extrusion patterns, immediately detecting material accumulation, filament deviations, and extrusion failures.
Detect issues early to save time and filament:
- Spaghetti
- Nozzle Clumping
- Air Printing
Pre-Flight Checklist by AI
Peace of mind, every time you print Prior to each operational cycle, H2Dâs vision system initiates a comprehensive pre-flight checklist: Chamber Integrity Scan â Detects debris across the entire print surface. Hardware Configuration Audit â Instantly identifies nozzle dimensions and build plate properties. Digital-Physical Alignment â Automatically verifies consistency between detected hardware specifications and active slicer parameters.
SOTA Filament Monitoring
15 sensors on one filament path Where legacy systems relied on a single filament run-out detector, the H2D engineers a complete material flow consciousness. Along the entire AMS-to-nozzle journey, 15 strategically positioned sensors form an intelligent monitoring web, perpetually tracking five critical dimensions: feeding velocity, tension fluctuations, filament tip localization, thermal environment in the extruder, and dynamic extrusion pressure - collectively establishing the industryâs SOTA filament behavior control system.
Whatâs in the box
H2D AMS Combo
- H2D
- Build Plate
- Spool Holder
- Accessory Box
- AMS 2 Pro
H2D Laser Full Combo
- Laser Edition
- Build Plate
- Spool Holder
- Accessory Box
- 10W Laser Module
- 40W Laser Module (Optional)
- Cutting Module
- Laser Platform
- Cutting Platform
- Emergency Stop Button
Frequently asked questions
1. Can H2D be upgraded to H2D Laser Edition?
The H2D laser full combo has a built-in air pump and air pipe on the back of the printer, and is pre-installed with a BirdsEye camera. The front door, left and right side Laser Protective Windows, and top cover are all designed with laser protection. The packaging list includes a laser module, a cutting module, a smoke exhaust pipe and its adapter, as well as an emergency stop button.
We plan to launch a laser upgrade kit for the non-laser version of H2D. The upgrade kit is expected to be released in June and will also provide installation instructional videos to help users complete the upgrade smoothly.
It is important to note that the air pump in the upgrade kit is an external air pump, which has a different installation structure from the built-in air pump in the full set. When using it, it can only be installed externally and connected to the machine through an air tube.
2. Are the left and right hotends exactly the same?
Yes, the left and right hotends have identical structures and materials, and can be used interchangeably.
3. What is the maximum number of AMS 2 Pro and AMS HT units that the H2D supports? How many colors can it print at most?
The H2D supports a maximum of 4 AMS 2 Pro and 8 AMS HT connected simultaneously, a total of 12 units with 24 slots.
Because H2D is a dual-hotend printer, and in the most extreme scenario, all AMS can be connected to one hotend while the other hotend uses an external spool holder, it can support up to 25 colors.
4. Is H2D compatible with first generation AMS?
The first-generation AMS has been confirmed to have full plug-and-play compatibility and can be used with the H2D for multi-color printing, but it does not support the AMS drying function.
Due to the fundamental differences in the feeding mechanism and buffering structure, the H2D does not support the AMS lite.
5. AMS 2 Pro is directly connected to the printer through the 6-pin ports, so what are the two 4-pin ports on the back of the printer used for?
The two 4-pin ports on the back are reserved for future expansion accessories. For example, to upgrade a non-laser version of the printer to a laser version, one of these ports can be used to connect an external air pump.
6. Can I use the A1 series Hotend on the H2D? Conversely, can H2D hotends be used on A1 series printers?
Although the hotend of the H2D series is similar to the A1 hotend in structure, it is not exactly the same.
The H2D hotends are specifically designed for the H2D printer, offering optimized compatibility. For example, they support a larger maximum volumetric flow rate, lower clogging risk, more precise nozzle offset calibration between the left and right hotends, and automatic hotend type recognition via the live camera. Therefore, to ensure optimal print quality, it is strongly recommended not to use A1 hotends on the H2D printer.
Therefore, to ensure you get the best print quality, we strongly recommend that you do not use the A1 hotend for H2D printers.
Purchasing additional H2D hotends for use on A1 printers is feasible. However, you will also need to use the H2D hotend silicone sock.
7. What are the differences between the 10W and 40W laser modules? How should I choose?
Both the 10W and 40W laser modules are blue light lasers that support processing a variety of materials, including wood, rubber, metal sheets, leather, dark acrylic, and stone. However, due to differences in power and size, there are the following distinctions:
- Maximum cutting thickness (For Basswood Plywood):
- 10W laser module: 5mm
- 40W laser module: 15mm
- Maximum engraving speed (For Basswood Plywood):
- 10W laser module: 400mm/s
- 40W laser module: 1000mm/s
- Processable Area:
- 10W laser module: Maximum processing area X310mm * Y270mm, maximum processing height 280mm
- 40W laser module: Maximum processing area X310mm * Y250mm, maximum processing height 265mm
8. Is a USB included as standard? What functions are affected without a USB?
The package does not include a standard USB flash drive. You can still initiate printing normally without a USB, as the printer has built-in storage space to run print files.
However, without a USB inserted, the following functions will be affected:
- The recording and time-lapse photography functions canât be turned on
- Printing cannot be initiated through the LAN
- Print files cannot be sent to the machine for storage through the studio
- Log files cannot be exported
USB requirements: USB2.0 protocol or above (actual minimum write speed needs to be greater than 10M/s), supported file formats are FAT32 and exFAT. And the printer only supports mounting one USB, and cannot connect multiple USB via a USB hub.
9. Why canât I freely select hotend for printing with the printerâs built-in files?
The hotend to be used for printing has already been determined when the model file is sliced. As for the built-in models, the right hotend has been selected during the slicing process, so it is impossible to change the hotend used for printing on the printer screen.
When you slice the file in Bambu Studio and send the print task, you can freely choose to use the left hotend or the right hotend. For some filaments, such as TPU and PPS/PPA-CF, it is recommended to use specific hotends for printing.
For more details on H2D filament printing, please check the wiki.
*Footnotes may apply to items marked with an asterisk
Bambu Lab AMS 2 Pro
AMS, Evolved.
The all-new 2nd-generation AMS 2 Pro features more powerful feeding motors that significantly boost filament feeding efficiency, accelerating multi-color and multi-material printing. Even better, the AMS 2 Pro introduces a filament drying function with active air vent on a fully sealed system, greatly enhancing drying efficiency and maintaining optimal filament conditions for extended periods.
Engineered To Better Dry & Use High-performance Filaments
Faster multi-color printing
The powerful Bambu permanent magnet synchronous servo motor accelerates filament feeding by 60% for enhanced efficiency.
Fast filament drying & air-tight filament storage
Automated venting facilitates dehumidification during drying and ensures airtight sealing for weeks of high-quality printing.
Serial connect up to 4 AMS 2 Pro & 8 AMS HT, total of 24 filaments
Supports multi-material and 24-color printing capabilities.
Key Features
Up to 65°C drying temperature
Provides effective drying for many filament types.
60% faster feeding speed
The brushless motor significantly improves feeding efficiency.
Auto-rotate Drying
During the drying process, the filament spools rotate automatically to ensure more even drying.
RFID Sync
AMS 2 Pro uses RFID to auto-match drying settings for Bambu official filaments, no manual input needed.
Speed Up! Faster Multi-material Printing!
Saves an average of 10 minutes per 100 filament changes.
Evolved, Polished Design Details
Easy-access Filament Tubes
See-through filament guide rails and a quick-release feeding mechanism make removing stuck filament quicker and easier.
Ceramic Inlet
Ceramic filament inlet, offering increased durability.
Accurate Temp/Humidity Sensor
Accurate temperature and humidity sensor for clearer readings.
Compatible With All Bambu Lab Printers
The AMS 2 Pro is compatible with all Bambu Labs products.
Specifications
Dimensions: 372 Ă 280 Ă 226 mmÂł
Net Weight: 2.5 kg
Housing Material: ABS/PC
Filament Supported:
PLA, PETG, ABS, ASA, PET, PA, PC, PVA (dried), BVOH (dried), PP, POM, HIPS, Bambu PLA-CF/PAHT-CF/PETG-CF/Support for PLA/PETG, and TPU for AMS
Filament Not Supported:
TPE, generic TPU, PVA (damp), BVOH (damp), Bambu PET-CF/TPU 95A, and other filament that contains carbon fiber or glass fiber
Filament Diameter: 1.75 mm
Spool Dimension:
- Width: 50 mm-68 mm
- Diameter: 197 mm-202 mm
RFID Identification: Supported
Highest Drying Temperature: 65°C
Filament Supported for Drying:
PLA, PETG, Support for PLA/PETG, ABS*, ASA*, PET*, PA*, PC*, PVA*, BVOH*, PP, POM*, HIPS*, Bambu PLA-CF*/PAHT-CF*/PETG-CF*, and TPU for AMS*
*Filaments marked with * require higher drying temperature. The AMS 2 Pro cannot dry them completely. If you want better drying performance for these filaments, we recommend purchasing an AMS HT.
Power Input: 24 V 4 A
Whatâs in the Box
- Bambu AMS 2 Pro
- Desiccant
- PTFE Tube
- Bambu Bus Cable-6Pin
FAQ
1. There is an independent power port on the AMS 2 Pro in addition to the 6-pin port. Is this necessary?
When the H2D is used with a single AMS 2 Pro, all functions, including automatic feeding and drying, can be utilized without an external power adapter.
When the H2D is used with more than one AMS 2 Pro, if some AMS 2 Pro units are used for multi-color printing while others are used for filament drying, then the AMS 2 Pro units used for drying require an external power adapter. The external power adapter can be purchased from the Bambu Lab official store.
2. Can the X1 Series and P1 Series printers use AMS 2 Pro?
X1 Series and P1 Series support AMS 2 Pro, if only the automatic feeding function is used, only the 6-pin cable is required, and no external power adapter is needed. However, if you need to use the drying function, an external power adapter is required for the AMS 2 Pro.
The AMS 2 Pro is compatible with X1/P1 series printers for multi-material printing. The filament drying feature for these older generation machines will be fulfilled through an OTA update by the end of April.
AMS 2 Pro compatibility with A1/A1 mini printers will be added through an OTA update in Q3 2025.
3. Can AMS and AMS 2 Pro be used at the same time for printing?
Yes, you can use both AMS and AMS 2 Pro on one H2D.
4. Can I dry filament while printing?
Currently, drying is not supported for AMS 2 Pro/HT that are actively involved in the printing process, including those that may be used for automatic refill during the current print job. Printing while drying is not yet supported.
The only âdry while printâ scenario currently supported is: the printer uses some of the connected AMS 2 Pro/HT units or an external spool holder for printing, while the AMS 2 Pro/HT units not involved in the current print job can be used for drying.
If the printer is feeding or printing, and at the same time powering 1 AMS 2 pro for drying, the drying power will be automatically reduced, in order to ensure that the printing power is prioritized. So it is recommend to use the external power adapter for best drying results.
5. Can I get power from the printer for drying?
The H2D printer supports powering one AMS 2 Pro for drying directly from the printer. If you need to dry filament in multiple AMS 2 Pro units simultaneously, the additional AMS 2 Pro units require power supply via a power adapter (purchased separately).
â
Bambu Lab AMS HT
Specialized for High-Performance Materials
Key Features
85°C Drying Temp
Specialized for high-performance filament drying. Drying temperature up to 85°C, optimized for high-temperature materials.
Automated venting facilitates dehumidification during drying and airtight sealing for weeks of quality printing.
Brushless motor improves feeding efficiency.
Dry Filament Quickly and Intelligently
Auto-rotate Drying
RFID Sync
AMS HT uses RFID to auto-match drying settings for Bambu official filaments, no manual input needed.
Bypass Outlet
Independent filament outlet designed for soft or brittle materials.
Ceramic Inlet
Over Temperature Protection
Accurate temperature sensor and physical failsafe for safe, precise heating.
Status Display
Clear digital display for easy monitoring of drying status.
The AMS HT will be compatible with all Bambu Lab products.
Specifications
Dimensions: 114 Ă 280 Ă 245 mmÂł
Net Weight: 1.21 kg
Housing Material: PC/PA
Flame Retardant Grade: UL 94 V-0
Screen:
Supports displaying real-time temperature and humidity, and remaining drying duration.
Filament Supported:
PLA, PETG, ABS, ASA, PET, PA, PC, PVA (dried), BVOH (dried), PP, POM, HIPS, Bambu PLA-CF/PAHT-CF/PETG-CF/Support for PLA/PETG, and TPU for AMS.
Bypass Filament Outlet: TPE, generic TPU, Bambu PET-CF/TPU 95A, and other filament that contains carbon fiber or glass fiber.
Spool Dimension:
Maximum Drying Temperature: 85°C
PLA, PETG, Support for PLA/PETG, ABS, ASA, PET, PA, PC, PVA, BVOH, PP, POM, HIPS, Bambu PLA-CF/PAHT-CF/PETG-CF, and TPU for AMS
Voltage:
- DC: 24 V
- AC: 100 Vâ240 V~, 50 Hz/60 Hz
Average Power: 150 W
Whatâs in the Box
- Bambu AMS HT
- Desiccant
- PTFE Tube
FAQ
1. What is the difference between the two discharge ports on the back of the machine?
The port at the rear of the top cover is specifically for TPU filament. Due to the softness of the TPU filament, it is easy to fail when using the AMS 2 Pro automatic feeding function. When using the TPU, insert it into the AMS HT and ensure the material tray rotates in the correct direction. Insert the material tube into the TPU output port and manually push the filament through the PTFE tube until it is fully loaded into the extruder.
Note: When using TPU, AMS HT cannot use the automatic feed and return function, but can be used as a drying box to prevent material moisture.
2. Can the AMS HT be used with the X series and P series printers?
AMS HT compatibility with X1 and P1 printers will be added through an OTA update by the end of April.
If only connecting one AMS HT to a X or P series printer, a filament buffer is required to be purchased separately. If connecting multiple AMS HT units, we recommend that you purchase an AMS Hub.
AMS HT compatibility with A1 and A1 mini printers will be added through an OTA update in Q3 2025.
3. Can I print and dry at the same time?
Printing while drying is not yet supported, including all the AMSs that are related to the on-going print job (eg. The AMSs assigned for auto-refill). However, you can dry filament in AMSs that are not assigned to the on-going print job.
4. How many AMS HT units can be connected to the X1 series and P1 series at most?
X1 and P1 series printers support up to 4 AMS HT connections at the same time.
5. Can the AMS HT be directly connected to the printer for drying?
H2D and X/P/A series printers are connected to AMS HT and use drying function. Each AMS HT requires an external 220V power supply for drying. It is not supported to draw power from the printer for drying (The power adapter is pre-included with the product package).
Can I expect an apology when the information released matches whatâs posted? Iâm really not sure why you think Iâd lie, I donât know any of these other people lol.
An apology for not having cached data? I think itâs fair for me to be skeptical if people claim that the webpage has stuff in the src when it very much does not on my computer.
Whoa⊠the price tag is gonna be scary if this is correct. Might edge in to Form Lab territory.
It looks like the information was removed from the site. It was there earlier, and now it is not. I will upload the full page source in a moment as a text file.
Thatâs a lot of text to just make up for the fun of itâŠ
Seems legit, and aligns with the previous leaks
Woah, thanks for this! Guess the only thing thatâs left is the price and availability.
There it is. Itâs just the page source from the Bambu Lab Accessories store page from a few hours ago.
Yes, I assumed they used ChatGPT or something. It does align with things Iâve previously found, like the laser and cutter modules, however that could have just been the AI getting speculations or something. If my computer had managed to cache the old version then I wouldâve believed it, however it didnât, so thus I was skeptical. Sorry
You are definitely correct to be skeptical, especially in this day in age.
Sadly, I couldnât find anything on pricing. Was hoping with the rest of the information available, it would be included, but no luck. I tried searching anything related to price, H2D, then just blanket dollar values (2999, 3049, 3099, etc.) but no luck and searching $ on HTML returns too many results since itâs used so often within the source.
the Ace Pro from anycubic needs to be plugged to an outlet, itâs not powered by the printer, this is probably the same thing
Found this:
âincludedAMSâ:â*AMS includedâ,âpriceâ:{âdefaultâ:âMSRP: USD 2,499(before tax)â,âusâ:âMSRP: USD 2,899(before tax)â,âeuâ:âMSRP: âŹ2.699 (VAT incl.)â,âgbâ:âMSRP: GBP 2,299(tax incl.)â,âauâ:âMSRP: AUD 4,099(tax incl.)â,âcaâ:" MSRP: CAD 3,199(before tax)"
I just searched the accessory HTML that all the above information had come from for MSRP with no results, where was this information pulled from if not that page?
