I’ve tried every possible setting change and I continue to get concentric grooves that must be sanded out (sometimes unsuccessfully), adding an already extra long print time to this sanding time - I’m getting really close to zero profit on these pieces, which are already at B2B wholesale pricing.
Can anyone tell me how to remedy this, without or with the least amount of sanding? I’m printing with SUNLU PETG on my year old, well cared for H2S. Variable Layer Height has been set to Adaptive + Smooth (screenshot below). BTW, I’ve tried it with and without the last two settings and there was a definitely positive affect to using Adaptive + Smooth, but the piece was smaller than this one in the image below that’s 3x the size, if that matters.
I’ve attached an image of the print and screenshots of my Bambu Studio settings. Let me offer my sincerest thanks in advance for whatever help anyone in this group sends my way ~ Alex
What Gerrit said stands, the steps are inevitable in 2.5D printing. But, If you grab Orcaslicer, you could try Z Antialiasing. I did not find it to help when I tested, but the model wasn’t a great candidate. Yours might do better.
You could also try to mask the aesthetic by changing your top surface to Concentric. You see those rectilinear zigzags next to the circles? Concentric will turn them all circular, so it at least blends more and you see less plateau
Indeed your use case was the reason why I went down the minimum layer height rabbit hole a while ago.
The ancient definition of an arbitrary percentage of the nozzle diameter as a “minimum” layer heigth is still aggravating for me. It has no basis in any actual physical failure modes. Purely some people on (social) media pretending to know what everybodys use case is…
The amount of time spent sanding can indeed make quite a few additional print hours very affordable.
I collected most related trials and a similar thread here (there’s a TLDR for your use case below though).
TLDR:
Try the slider for adaptive layer height in the range of 0.0 to 0.3. That is where you get the best quality but can still trade a little time. Also, the layer height graph pupping up on the right can be manually tweaked. Left/Right click on the layer chart to in-/decrease local layer height.
You can use the machine settings to further lower the minimum layer height used in adaptive layer height. 0.04mm is pretty safe for PLA on the Bambu’s (sorry, haven’t tried for PETG). Recently, I noticed Bambu implementing some pointless restrictions on it (X1C), but Orca should still allow more freedom.
The first actual physical limit reached when reducing layer heights below 0.04mm tends to be flow control: In very low flow conditions, the extruder is no longer able to exert sufficient extrusion control. The H3C/P3C may be a little better.
To increase flow control, speed can be increased to get even lower. Multi-color sub-layers crank up the speed to 350mm/s to achieve 0.02mm sub-layers. Sadly, PETG does not respond kindly to this. Infill will be shredded.
Larger nozzles are also able to maintain flow control for longer. If the part is shallow but with few sharp features, they can help a bit.
Another item that pop’s up around 0,03mm is cooling. With such low layer heights, cooling will be almost instantaneous.
At 0.04mm layer height, layer lines are still visible, but only barely. At 0.03, I have not been able to see them anymore. At 0.02mm, I could not feel them anymore.
==> Try out the 0.04mm adaptive layer height using high quality settings for adaptive layer height.
There are a few spots visible in your dome pic. I am not sure if those are seam artefacts showing through the or if it is related to solid infill inner edge warping. That can happen on larger prints with “Ensure vertical shell thickness”.
That setting ensures that sufficient walls are printed underneath shallow angles to keep the perpendicular wall thickness at the minimum value defined. Unfortunately, this can lead to wide swathes of solid infill printed on the sparse infill. This has a tendency to warp upwards badly in particular if the filament is slightly moist and the solid infill width is large. Such areas should show up in the preview though.
Thank you ALL for the input, a few hours deep diving into it all and I’ll feel like a Lay Height Pro! This morning I received this from my brother: Print Calibration Video
Have any of you run this test or even knew it existed??? I HATE Bambu’s tutorials (what they consider tutorials)! As a teacher I find their instructions very user-UNFriendly! All of you are wonderfully far more effective and truly helpful! Thanks again for helping me out!
Your adaptive setting is backwards, you have the slider all the way over to the speed side, try it over to the quality side. Sphere shapes can be tough to get smooth.
