Hardware Parts & Electronics Product Information Update
Hi MakerWorld community,
Please share your questions regarding using Maker’s Supply Hardware Parts & Electronics in this thread. For more information, please check Maker’s Supply Product Information Update.
Guildelines
  • Everyone can post questions about Maker’s Supply Kits and Parts in the matching Maker’s Supply Category. Make sure to include the product links in the post. It’d be great to follow this format:
    • Maker’s Supply Kits and Parts: [Name of the kit or part]
    • Product Links: [The actual link]
    • Questions: [Your specific question]
  • Both the Maker’s Supply team and other creators can answer the questions.
  • We encourage our users to vote for their favorite answers by reacting to the answer with the “clap” emoji.
  • We’re looking for answers that have:
    • Examples of how the product can be used in different models.
    • Step-by-step instructions on assembling the product with the model.
    • Pictures of the product in action with the models.
  • We’ll update this official thread once or twice a week. In the update, we’ll have:
    • Contributors with links to the MakerWorld profiles of those who gave the best answers.
    • A summary of all the questions and answers, so other users can easily find what they need.
  • We will select contributors based on two main criteria.
    • Who are able to provide the answer that meets the formatting requirements and offers valuable insights and practical solutions.
    • Secondly, who received the most “clap” emojis.
Contributors:
Summary
  • Maker’s Supply Part: Electric Push Rod
  • Product Link: https://us.store.bambulab.com/products/electric-push-rod
  • Questions:
    • Does anyone know of models that have used this part? I haven’t been able to find any.
    • The pinout of the connector looks like a standard servo - is this correct?
    • What would be the recommended control mechanism? I could use Arduino but I’m trying to think of the easiest, no-solder way so that projects would be easy to assemble by end-users. Also, for easy of ordering using something like Arduino would complicate the BOM.
    • Regarding control, I’d be interested in mechanisms that are either triggered by a button press or are just cycling.
I can imagine a lot of potential scenarios where this part could be useful but am just hoping to learn from anyone with experience!
    • There are actually zero, yes. Most likely due to the lack of compatibility with other Maker’s Supply parts. You can find stuff that uses a specific part by google searching “"PARTNUMBER" site:makerworld.com” This will pull up everything that has that part number that is on makerworld.com. It works well for me. You can also set up advanced search filters using the Google advanced search menu or other search modifiers. E.g. “"PARTNUMBER" -lamp site:makerworld.com” would pull up everything that is not a lamp but has a specific part. Pretty cool!
    • Yes. There is currently no way to easily integrate them with other Maker’s Supply components. I’m hoping for a micro controller of some sort soon that will let us do this.
    • That could in theory be accomplished with the same type of receiver as a model airplane.
They appear to be used sometimes in model airplanes, for example to adjust the wings. They can be controlled using a standard airplane RC receiver system or an Arduino. This video shows a similar actuator being controlled using an Arduino and a relay.
This is incredibly helpful - thank you!
Recently, I’ve been using the COB LED lights in multiple projects and have found them versatile and convenient. Below, I wanted to share answers to some of the questions I had before using these parts.
Maker’s Supply Part (product link to US Store: COB LED Strip Light
Q: What is the diameter of the LED strips?
A: The store listing indicates that all three sizes (300, 200 & 100mm) are 1mm in diameter. In practice, I find that that the diameters are closer to:
  • 1.9mm for the 300mm LED
  • 1.6mm for the 200mm and 100mm LEDs
Q: How can the LEDs be attached to prints?
  • Within a tube: for applications without significant movement, I’ve found this to be a stable method. In the GIF below, I had run the LEDs through a tube and had a small cross-bar over the top. Bending the strip over this bar provided plenty of tension for a stable hold.
    • PXL_20241231_210607847~3 (1)
  • Inset within a channel: when mounting the strips to a surface, I use a Boolean operation to create a channel with a lip that holds the LED in place. Given the rubbery coating, I’ve found that this can create a strong hold. I use these measurements (also included as an STL) for the Boolean object and extrude it into the shape I need:
  • This example STL includes channels for both a 300mm and 200mm LED with a pass-through for the PCB to stay hidden in the back. The diameter of the channels is just enough to hold the full length of the LED for each size.
  • Magnets: Although I haven’t tried this myself, other users have mentioned using magnets and self-tapping screws such as in this post.
Q: How flexible are the LED strips?
A: I haven’t stressed the components enough to bring them to the point of failure but have bent them to 20 degrees without any issues. Similarly I’ve wrapped them around a cylinder with a diameter of 7mm without causing any failure. Mechanical pencil for scale:
The flexibility of the strips I can allow for them to be placed in tight quarters where wiring could be difficult. Thin this example I’m feeding them through a channel at a 90 degree angle so that all of the wiring can remain contained within a separate space.
Q: Is light emitted evenly around the surface of the strip?
A: The actual LEDs all face a single direction but the rubber material diffuses the light. I don’t have a way to measure this accurately but would estimate that the back side is around 75% the brightness of the front.
Because the light is diffused, I find that these LEDs can be a good solution for providing light across a large area vs. using several smaller, directional lights. In this example a single LED is providing light behind many small windows on two sides of an object:
Q: Are these suitable for moving parts?
A: Maybe but in my use cases, I have needed to be cautious of any movement of the LED strip or wires leading to it. At first I thought there was a short in the SH 1.0 wires I was using but have seen the same flickering behavior across multiple wires, power distribution boards and potentiometers.
Thank you for this information! That is extreme helpfull my friend!
Bambu should state this at their shop site in the category of the makers supply. This way more people will take notice of that helpfull task!
Hi MaKim
I came across this topic while searching for information on the electric push rods sold by Bambu Lab. I didn’t find any info so I started messing around with the push rod using the Cyberbrick transmitter/controller and app. After a bit of experimenting, I got the push rod working with the Cyberbrick transmitter/controller using the 3-way switch to control the push rod as follows:
O = stop
I = retract
II = extend
I am still hoping to find a way to control the push rod by sending it to a specific position (extention length or retraction length), but I’m not sure that’s possible.
When I bought the push rod (LA011) I had a specific project in mind, but now that I’ve got it (semi)working, I’m not sure it will work for me since the speed is relatively slow and I haven’t figured out how to get it to extend/retract to a specific length. I will keep experimenting, but given that there is literally zero info on how to use these electric push rods, I figured I’d post this here in case anyone is interested.
Let me know if you want the configuration I used to get it “working” with the Cyberbrick transmitter/receiver.
Cheers!
Thank you! I hadn’t thought about using the 3 way switch but will have to try that using what you provided.
It’s really interesting that you were investigating this because I was just trying to incorporate the push rod with CyberBrick yesterday but with the 2 axis joystick.
With the joystick, you can extend or retract depending on the direction you press the joystick but, like you, I have also not found a way to send a specific location. If you figure anything out, please do share it!
New stuff! Soldering iron!
Nice kit indeed!!
Thank you for the heads up on that one! My soldering iron is garbage! Can’t wait to give this new one a try! :smiley:
