Has anyone been able to print in ABS with the A1 mini? Is it even possible to make an enclosure to print in ABS? Could you somehow print in ABS without an enclosure? Also if you have can you give a picture of your printed object and the settings for it.
Try to use draft shield or tall skirt.
Read this:
Do not waste your time , i tried it on other printers with out enclosure and is doable but next to impossible for reliable and good layer adhesion without warping , think of how to make simple encloser and possibly heat it , or most cases heat bed is enough . Check quite a few forums with ABS/ASA printing for X1`C and P1S you will see the challenges
I have tested the Easy ABS from Sunlu on my A1 mini and it seems to work fine… printed at 235C and heat bed 80C, no enclosure, at room temperature 25C. Upscaling 100,5%
I could not see any warping and it sticks fine on the textured build plate, without glue. There are also some drawbacks with the Sunlu Easy ABS, all explained in a video on youtube (search for Sunlu Easy ABS)
Here are some pictures from my first attempt
Thanks. That turn out pretty well. Have you tried the bambu lab or just sunlu?
I have tested only the sunlu easy ABS on the A1 mini so far. It has some better mechanical properties than PETG and can be smoothed with acetone. Low HDT ist the biggest drawback.
I have experienced how challenging normal ABS can be even for enclosed 3D printers. So IMO there is almost no chance to print “normal” ABS with the A1 mini.
But there are some other “easy” ABS variants that seem to be interesting, e.g. easy ABS from fiberlogy… The manufacturer claims that it doesn’t need closed chamber, but it requires slightly higher build plate temperature (90…100°C). Maybe it works with glue…
I have printed two samples with the transparent Easy ABS from Fiberlogy, that I mentioned in my last post.
I used a glue stick for the build plate to make sure it was not warping up.
My settings: bed temperature 80°C, nozzle 255°C at 23°C room temperature. I have slowed down the print speeds. It took about 3h for each sample to print.
The first sample is a simple box (70x70x40mm) printed on the smooth plate.
The warping on the front left corner is negligible
The second one was printed on the textured plate (+glue).
I could not see any warping at all.
The material is not really transparent, it’s translucent … but looks nice.
You can also check the datasheet from Fiberlogy Easy ABS for more informations.
IMO the results are looking good, so it is possible to print some ABS filaments on the A1 mini, without enclosure.
Great result one note on easyABS, try to heat it. so no good for anything which requires a bit more heat it is worse than PETG and not far from most PLAs
That turned out really well. It seems that any “light” ABS should work okay with the A1 mini as long as you go slow.
Generic ABS is possible too. I Just got a perfect print from an old CEL Robox red filament I had lying around at 255°C, 80°C bed and no part cooling fan at 100% speed. Just used a bit of glue from an even older UHU stick.
I’m sure I could have gone lower with the temps. Might try later.
Printed perfectly on my A1 mini with 25% speed and acceleration, 10% cooling and 235°C nozzle and 80°C bed temperature.
Filament ABS+ from ESUN.
Now need to try with 50% and 100% speed.
Got few fails before with trial turned off 0% fan…
After some time using this wheel holder, I may say, that 235°C is not enough for adhesion between layers, so I setup 250°C and printed with 100% speed well.
@TheSlider Welcome to the community, ![]()
I got much better success for larger parts where I set the layer hight to 0.35mm instead of 0.2mm. The 0.35mm layer ensures there is much more ‘energy’ aka heat in the ABS so it will stick better with the layer below. Well, that’s the idea…
Then try to print as fast as possible, so prefer only one object per print. Doing multiple objects where the print head moves from part to part has the unfortunate consequence that parts start to cool off to much.
For example this I printed in ABS: Low Friction Adjustable Spool Holder for A1 mini by rogerquin - MakerWorld
I printed each roller part separate but as fast as possible. The small one took 30minutes, the larger one takes about 45 minutes.
The bearings I forgot…
everything ofcourse with brom of 5mm.
No worries if your ABS prints are on the smaller side, an enclosure might not be necessary. But for larger parts, aim to have at least a cabinet to print in!
Anybody with an Overture ABS profile? (not the easy ABS one) Thanks !
Blockquote
I may say, that even small parts is not strong enough with 0.2mm layer height, while 0.16 much more stronger and stable.
Interesting someone tried use new supertack plate with ABS? With PLA and PETG advertising shows miracle. While its not developed to ABS, possible it should solves adhesion problem with ABS.
Hey folks ~ new to the hobby here and just got my A1 mini. I wanted to print my wife some stuff to decorate the house with. I got silver Bambu ABS but for some reason no matter the project it says the ABS is incompatible. Can anyone help me?
