release a 500X500X500 printer with zonal plate heating for domestic customers?
Is this where we submit words to fill in the blanks, to get points and prizes for the quiz show?
My suggestion is āmake a robot panda that can change build plates in a print farmā
Iāll have some of what this chap is on ![]()
Not very likely.
Bambuās domestic market is China. Why ask here?
The Bambu build plate cannot be put into a 2x2 configuration because of the notches on the top.
You need to print on a raft to use the seams on a multi-plate. I do not think Bambu will like this.
A single large build plate will be expensive.
EDIT 5) For what in the hobby market is a plate this size of 500x500 required for? Cosplay helmets fit in smaller. This is a furniture printer, and itās not enclosed so canāt use special filaments to make stronger prints.
EDIT 6) You do NOT want to know what a high temperature enclosed 500x500 machine costs. At this size, thermal expansion of the rails will cause problems, and machines become VERY expensive.
I meant non commercial, like my house or yours(non commercial and non farm)
Not applicable to my question
see #2
yes, and Bambu can charge with profit for the lesser volume theyāll sell to people like me.
with all due respect it is my money and none of your business. For all you know Iāll hang it on the wall like a painting.
not convinced on your arguement regarding temperature (cost not an issue), but hey you sound like you know.
Ok, since youāre the font of all knowledge, enlighten me.
Will Bambu, in your opinion, ever release a larger format than the H series ? like 400 cubed or 450 cubed ?
They meant Prusa XL style of heatbed tiles, not the build plate shape.
500x500 printers show time and time again that the amount of work is needed to keep that gantry moving and more importantly move it in a straight line is super hard. Just look at VCore 4 500x500 and see the amount of beef required to make it work. Thatās not really a Bambu Style.
Also ⦠500x500 printers do not fit into a typical apartment/house door jambs. With packaging - you wouldnāt be able to sell it into a typical residential space.
So⦠if there is no market ⦠then Bambu is not going to make it. Business decision 101
H2d/c is like 100lbs. I nearly blew my back out lifting it alone. At what point would it be too heavy for a consumer to realistically deal with it?
Linear thermal expansion coefficient of Aluminium = 23.1 µm per degree per metre.
500mm aluminium would expand by about 0.3mm if heated by +30 celcius, which is what would happen if the frame was enclosed by a heated chamber.
Imagine 0.3mm expansion sideways against precision linear rails and guides, and acting against the steppers. This printer will not print right, and is not long for this world. (EDIT If you have enough slop in the machine that 0.3mm can be absorbed, then how accurate is your printer?)
Some type of system must be built into the machine to compensate for this; I do not know what they use but they must use something. Either some complex system of flexible mounts, or the machine is the size of a small car. (EDIT I just saw that the Mingda 600mm heated printer is 1200mm (4 feet wide) and weighs 330 kilograms (770 lbs); which I concede is smaller than a car, but will not fit in most homes; does anyone know of a spring-based mechanism and what it costs?)
OK, but still need need new build plates
I do think the heatbed of the H2 series is bad, and they need a new one. It does not heat very uniformly.
Yes, I agree with that H2 bed is not really a great design. I was able to mitigate it by using IDE G10 plate. Itās very thick and heavy, has thick steel backing that improves heating uniformity by a lot (verified with a thermal imager)
Open machines of that size are OK. Comgrow make a usable one. (Comgrow are related to Sovol somehow). It works because itās 40 kilograms. I have no idea why Reprep are having problems, but thereās a probably a reason why Iāve never seen one of their machines in the wild.
Same issue which is why I also use mostly G10 on a thick steel plate. I let it heat soak for a bit and only then get an even plate temp.
It does not heat uniformly initially but after some time it does average itself out reasonably well. Could be better, but I certainly canāt attribute any problems (with my prints ofc) to itās current state.
I have had poor bed adhesion with large prints because of the bed. For me raising the bed temperature by +5 solves the problem.
If raising it 5 degrees solves it then itās hard to positively identify āuneven heatingā as the source of the issue. Correlation not necessarily being causation and all.
I agree that it could be improved, and there may be some niche issues from it, but with a little soak time it evens out fairly well.
