900 hours, cleaned the rods and lubed the screws once. No printer failures or replaced components. No complaints.
Am I the one printing the most? ![]()
4500 hours now, and counting⦠;-D
Since my last post I was battling backlash, so I changed the XY belts (probably not needed), Z belt (definitely not needed), adjusted the Z screws that jumped tooth somehow and did some tramming, then put shims between the toolhead and the top bushing which solved the problem.
Prints as good (or rather better) than new.
I wonder what the projected lifetime of all the components isā¦
4500 hours! Wow, thats alot ![]()
can you make a picture of what you did to the toolhead?
Take a look here: Extruder has play in Y-Axis
Thank you for sharing zviratko, Iām sure many will find that thread useful.
Really happy to see so many hours being positive on the X1C. I just purchased 2 X1Cās with AMS in the last month, and so far doing great, minus one print that consistently fails (exhaust fan mod on overhang). Glad this forum is active!
about 2300 hours lots of fails even more successes
So here we go, he is only at 1000 printing hours per printer (total of 3000 hours by 3 printers) but that will certainly change quickly because thise machines have to deliverā¦
Iām excited to see what happens when he reaches the 5000 hour mark per printer on 9 printers - what in something that is: lightly used.
Finaly I see it like he see`s it, you can really say something after 20,000 printing hours per printer, so a total of 180,000 printing hours by 9 printers.
Only replaced the top PTFE line twice now, had to clean out the extruder of gunk, and one fillment cutter. Not bad for a machine that hit 2000+ hours primarily doing ABS and getting cleaned once a week.
dude ⦠sorry for your printer ⦠but this topic is about printing hours not DOA ā¦
I probably have 500 hours on my first X1C and maybe 300 on the second one. I havenāt any major issues with either. Iāve lubricated the lead screws and thatās about it.
We just got a set of 3 to over 1,100 hours, mostly in a two-week period! Nothing but trivial maintenance issues - the AMS not retracting filament once in a while at the end of a print, someone uploading G-code for A1 instead of X1⦠that kind of thing. Otherwise Iāve been thoroughly impressed with their performance!
I had over 300 hours on mine, and for some reason it now shows it zeroed out after the update.
Did you perform a factory reset?
Another number:
500 printing hours in a month at more than 20 kg of filament.
Recently I read a post where someone said he had the quality of another brand because he prints 50 kg of filament per month. I just read that and didnāt reply. My own thoughts on the statement were just, do you run a printer farm with 2 printers? 50 kg is very close to the private consumption of a private houseowner who gets a little something doneā¦
I often criticize Bambulab, but somehow they impressive me during the last 3 Weeks - Iāve slaved my X1C printer since 2 month and made him work day and night he do not give up - impressiv!
Got mine on 24 September 2023 and have used it for 1504 hours. No issues apart from having to file away a piece of the filament sensor to fix an error when using the AMS.
530 on my X1 Carbon.
I got my unit yesterday. So about 4 hours before the print head overheated and let a bunch of horrible smoke out.
i got my X1C on July 2023 from a friend with 384h, now its rised to approx. 1.7k hours. Sometimes i have little noises, while moving the toolhead, i have tried everything: cleaning a.s.o. but with the new noise canceling update this noise is now reduced or there is nothing to hear. But the print is not very clean, the Z Axis has Wobbles since 2 months. I read about the problem. Mostly the first versions have this, because there is sometimes play in the bearing for the X-axis of the toolhead inside. This x1c is from 6. JAN 2023, so an early bird! The newer Version, does have the updated bearings inside the head. so maybe i will buy for 100⬠next months a new axis with bearingā¦A friends X1C is younger and is running without any problems for 4.3k hours. so sometimes its better, waiting 6 Months for newer updated version. Bambu supports solution is to fix the play with duct tape, to minimize the play of the X-Axis. Not very satisfiying
There are no more problems and the 1st Nozzle is working good so far!
