Over 2800 hours on my X1C, and the only work besides routine maintenance has been unclogging the nozzle two times, disassembling the hot end to pull out broken filament once and I replaced the extruder gears around 2500 hours, although Iām not sure it was necessary. Still using the original 0.4 hardened nozzle but Iām thinking about changing it just because Iāve been sitting on a bunch of stockpiled parts that I have on hand and not needed. Truly an amazing machine.
1200 hours on mine and the micro lidar failed. Out of warranty but filed a support ticket anyways. Super support from them and problem resolved! Thank you Bambu support!
on the printer you go to the settings > general > device info
mine is clocking 2492 right now, and itās been rock solid - recently had to change extruder gears, and iāve been through a couple of nozzles, so just consumables issues
the only issue i actually had was at the very beginning, where the connector board for the AMS connection was glitchy, and support sent me a replacement, no issues since
2342 Hours X1C
Running mostly PLA basic using 0.4mm hotend
Had to replace hotend after using PLA Sparkle. (plugged)
Other than standard maintenance (cleaning & greasing) no other problems to report
169 since August.
So far I mostly used PLA CF and Basic PLA.
Iām still experimenting and Iāve already bought PETG and ASA CF for my future projects.
Requiescat In Pace, you poor and innocent mainboard fan⦠Youāve did your duty faithfully until such time when your cruel owner sent you to (permanently) lay down 6 feet under the daisies⦠What a life⦠what a fate.
Is there no z hop setting you can use to lift the head when travelling? You should also be ableto tell the slicer not to allow the head to pass over the part when travelling. ( travelling is when the head is moving without printing)
