So if someone is wrong we are not supposed to point that out now? Grandpa was leaving important details out which gave the wrong impression to others. His ambient environment, while not super dry, is adequate to get prints out especially if he has tuned out some water effects. He’s close to the edge but he gets away with poor drying techniques.
Your post was largely just wrong with what you said about water absorption and hydrophobicity.
I don’t know what you want me to do here. I tried to be nice to Grandpa and used lots of wiggle words, but his advice was bad. He made out like he didn’t need to dry so others don’t either - which is flat out wrong. You implied the same thing and laid it all out again.
Go back and read my reply to Grandpa. I didn’t dismiss his experience as not mattering. On the contrary. I said it was important to include all the details which others can use to see if his experience applies to them.
You have a room dry enough to store and print with that doesn’t require you to dry. That’s great. But my ambient was hitting 40% and I was seeing water effects - effects that went away once I was drying effectively. Relative humidity does matter. It may not to you but it does to other people.
That’s the whole deal, Ed. All your numbers are 30% or below. My personal threshold on PLA is 25% and even then I see water effects until I get below 20%. You are in the ballpark. You apparently don’t need to dry and good for you.
So you tell me. You come in here and proclaim you live in a rainforest and don’t have to dry your filament. You say you leave filament out in the open, again implying you’re in a humid environment and you can treat PLA just any old way. You now give 30% as your high humidity when in your reply to me you said your room was 40%. Whatever.
The thing is it’s good to have people post the real information, not hidden in prose about rainforests, flower pots, and room humidity when you use dryboxes. That’s what piqued my interest in your post to me - you belabored how wet everything was and yet you didn’t need to dry. That’s deceptive. That’s why I mentioned actual humidity.
And your discussion of hydrophobic/hydrophilic isn’t based in reality. You also apparently don’t appreciate the difference between injection-molded polystyrene and something called polylactic acid. You also don’t appreciate surface morphology, cracks, pits, and fissures. All this stuff matters.
Have you looked at a micrograph of filament? Filament is extruded to manufacture it. Some think that filament should be just like the things we print. It’s not. Extruded filament is being cooled so it holds diameter and doesn’t just drip out of the extruder used in production. It’s done fast. That leads to a very different surface than when molten filament is extruded for a print and cools in place. Things printed with filament get much smoother surfaces so water can’t attack it the same as the rough surface of a filament strand.
And you are also just wrong about PLA not reacting with water. It does. It’s a slow process when the surface is smooth because the surface area is way lower. The PLA undergoes a hydrolysis reaction. It is a real, honest to god chemical reaction that changes the PLA. It attacks the ester functionality and breaks the polymer into individual lactic acid monomer molecules. That is a chemical reaction.
But again, this isn’t a reaction you can easily see with your Mk I eyeballs. The molecules’ sizes are measured in nanometers and smaller. You can’t see it but it is there and it is happening - flower pots or no. PLA will degrade in water. Another experiment you can do yourself just like recode did.
You could also have looked all this stuff up for yourself. Instead you post like you know all about this stuff except you actually don’t. Look up hydrolysis of PLA. Look up micrographs of filament strands and learn the differences between polystyrene and PLA/PETG. And learn about reaction rates. Dunking something in water for a minute is very different from submersing it for days or months. Time does have a toll. A much smoother surface will greatly extend how long things can be exposed to water compared with rough surfaces.
Anyway, whatever. It’s not fair to other people here to post about 100% humidity in a rainforest and how you don’t have to dry your filament when a little prodding and we find out your conditions are actually pretty dry. That’s why you don’t need to dry filament. Not because PLA is so forgiving. You were embellishing your story to make it sound better and so made it deceptive.
I guess we aren’t supposed to call that out now.
