How rename printer? Or is that a no-no?
Howdy mates,
Swedish noob here with yet another confusing topic (for me)
Wearing out the Screen with Bambu X1 C YouTube videos,
I noticed that a few has renamed their printers…
How does one do that - and does that clash with anything or is it a really bad no-no?
May the force B with you mates!
/Silverbullit
  1. Printer on
  2. Open Bambu Studio
  3. Select the Device Tab
  4. In the upper-left side of the screen will be the printer’s name, click on the printer name.
  5. The printer’s name will appear again in the drop-down list, click on the pencil-in-square-box icon.
  6. Rename the printer in the popup box.
I hope this is what you were looking for.
Thank you Brshoemaker,
That is awesome! :smiley:
Since you are knowledgable, is it O.K. to rename or will the chain phone/pc/x1cc loose connection/synk or will something bad happen if renaming? Or will it just continue work flawless? :partying_face:
Thanks again mate!
/Silverbullit
I wasn’t sure the answer, so I changed the name and nothing bad happened. The name change showed up on my phone app as well. Everything seems to be working. I assume the name is just a name for your benefit. Likely Bambu Labs uses a serial number in the background to associate the printer with the cloud, phone app, and Bambu Studio.
Also, I found a place in the phone app settings where the name can be changed as well.
Thank you so very much my friend! :+1: :partying_face: :+1:
I went thru the steps, to rename the printer, and there is No pencil icon, on the drop down list?
is this Windows or Mac specific?
You can also rename your printer in the Bambu Handy App.
It will sync the name change to the Bambu Studio then.
This definitely works. In Bambu Handy click on the menu icon in the top right corner and then click “My Devices”. This will display the current printer name. Change it to what you want and then click “Confirm”. As noted it will be reflected in Bambu Studio as well.
Thank you, it looks like the Handy App for doing this is much more straight forward than the Mac version of Bambu Studio.
Thanks Again
I do not believe the rename will work in the LAN Only mode.
Yep, that’s my current problem. In LAN Only mode you cannot rename the printers from their weird default name. Yet another feature Bambu should have implemented from the start.
Well, it’s 2025 and you still can’t rename a printer that’s in LAN only mode… which is a problem, as I’ve now bought enough X1E’s that they’ve shipped me multiple with duplicate names. As you can imagine, duplicate named printers + printer farm = bad times.
I can’t run these outside of LAN only mode. I can’t connect them to Bambu’s cloud. There’s gotta be some solution here, otherwise I’ve gotta return a bunch (>10) of X1E’s.
I have also been looking into this. One work around I found is to temporarily bind it to a Bambu account via a phone hotspot, then in Bambu Handy change the name and revert your X1E back to LAN only. This should keep your home network from being connected to the Bambu Cloud if that’s the reason for keeping your X1Es on LAN only.
It took me the better half of a day but I successfully renamed three Bambu P1S devices for LAN use - this method does require briefly binding with the handy app.
1 - Turn off LAN and bind with handy app
2 - In app settings, depreciate firmware to 1.05.01.00
3 - In 1.05, factory reset the device
4 - Scan QR with handy app and confirm the name you want to change
5 - In app settings, bring firmware back to 1.07 (highest firmware which still allows LAN use)
6 - On printer LCD, it will now have the name you configured while in 1.05 firmware
7 - On Handy app, press delete device to unbind. On printer, turn back on LAN mode
8 - On Orca perform a fresh rebind by pressing +Bind with access code (don’t select the printer in drop down)
Note - step 8 gave me trouble, I wasn’t able to get Orca to forget the old name for one of four printers that I performed these steps for, despite the LCD on the printer confirming it was renamed.
Greetings from Germany
I don’t know if someone find out this earlier… so sorry no bad intention here…
I was able to rename both of my Printers (A1 and H2D) without connection to a Bambulab account. With help of the farmmanger server/client. Perhaps somenone can test and verify this. Both printers have the latest FW.
I did the following things:
  1. Install the BB farmmanager server and client
  2. Did the initial configuration
  3. Temporary disabled the “Lan only Mode” on the printers (I don’t connected it to an BB account)
  4. Added them as new printers to the Farmmanager
  5. Renamed them with the Farmmanager.
  6. Activated the “LAN only Mode” again without removing them from the farmmanager.
  7. Uninstall the Farmmanager Stuff
I did a reboot of the printers, to test if the renaming is persistent… looks good until now.
Best regards
Hi,
I managed to rename it this way:
- I disabled the LAN mode on the printer
- In the Bamboo Handy app on my phone, under “Devices,” I selected “Bind Printer” and “Pair Nearby Devices”
- Make sure you’re connected to the same Wi-Fi network as the printers, and you’ll see them all there
- Select the printer you want and rename it
- Re-enable “LAN Only”
- Enter the new PIN, and Bamboo Studio will automatically recognize it by the new name
- It takes a maximum of 1 minute for the LAN mode to take effect
Good luck!
