How to print very small parts without spaghettification?
I made some gridfinity baseplates from gridfinity generator. Now I need to connect them, same website has connector for it. When I try to print them in my P2S I get spaghettification or filament not sticking to bed. Here is the images of what I try to print and how it came out(Second photo its from the first try). I tried to print by object, by layer, slowed down printing speed in Bambu Studio, by putting it to silent mode. Still out of 5 connector’s that I tried to print 3 different way’s only one come out fine. How can I print such a small objects without those issues?
Edited because you don’t deserve to read it again :man_shrugging:t2:
Please refrain from posting comments, if you don’t have any solutions or advices. What you said, its literally “you doing it wrong, do it right. Don’t know how to do it right, read up”
Hi! :smiley:
Place the parts closer together, and use brims in your global settings. (I prefer outer brims since it’s easier to clean out). Increase the amount of brims (it’s usually about 5 mm, so go up as much as needed) to generate a full domain of connected brims, which holds the tiny parts steady enough to print without making them spaghetti.
Hope it helps! :slight_smile:
Thank you for advice, I try it out and give feedback
Thank you again, I applied your solution and everything came out perfect
