Idlers with Tooth
I found here and in reddit that both the X1 and P1 series should use Idler Timing Pulley 20 Tooth Wheel Bore and a lot of the frequencies problems at high speed will be fixed but I haven’t found any information regarding why the printers doesn’t use them if they cost almost the same but by don’t doing it the users can incurs in a lot of other problems because it requires to disassemble almost the whole printer.
Have a read through this long thread.
Specifically starting at this post.
yes to both, and regarding the second one is my main focus, this cause a lot of problems
