Ironing percentage
The H2D hot end impacts the filament more significantly than other printers.
You can also try adjusting the nozzle temperature for the top layer of your part, if possible, by using layer specific temperature G-code.
To change the temperature at a specific layer
Are you using higher iron speeds and require increased flow?
