is it possible to upgrade the p1s to x1c
It isn’t about the lidar. They use different electronics.
-sell your p
-buy a used x
It’s more about the microcontroller used on the P series, it’s way more limited than the one in the X series.
If you really want this then do as movingimage suggested, or perhaps try and incorporate an iphone into some additional electronics to warn you (AFAIK it has LIDAR).
can anyone recommend a third-party live-feed cam to plug into the p1s’s usb port? (the 1st party cam’s quality is trash, 0.5 fps)
If you are hoping to switch camera inputs, it won’t work. The main processor of the P1x is too slow to process video at full speed.
If you’re just looking to use the USB port as a power source, then any small WiFi cam should do the job and stream to your phone or PC. It just won’t be integrated with Bambi’s apps.
