Surprisingly, the white PETG Basic came out as matte as HF and it’s much whiter. Are the darker colors more glossy like the PETG should be? Thanks
Just a quick note: The glossiness depends also on the print settings you use, so you can adjust it yourself within the realm of possibility. Of course, this doesn’t make a matte filament shiny, or vice versa.
Unfortunately, I don’t have anything else to compare it with in terms of PETG at the moment, just Silk PLA, but I think this illustrates my point:
Bambu itself illustrates its new PETG white with this reference photo:
However, you ask for dark colors?
I’ve only tried the black and blue Basic so far, and they’re both noticeably more glossy, or less matte, than the HF versions. I’m not sure I’d call them “glossy” per se… semi-matte or satin would be closer IMHO. Print lines are a little more obvious, for example, but nothing drastic. Sorry I don’t have any photos or examples to show off at the moment.
-Max
PS: Some comparison photos of black in this post: BL PETG Basic - #31 by Sebo3D1
Printed a bunch of parts in PETG Basic white and they came out fairly matte finish.
Also not as high quality as I get out of PETG HF. Might need to tune it to get better results. Prints were acceptable though.
I would call it semi-matte. It is less glossy than Sunlu regular PETG. It is more glossy than bambu petg-hf, and sunlu matte PETG.
Have you printed with Sunlu Matte PETG? I know eSun’s Matte PETG is the closest to Bambu HF in terms of finish, but it doesn’t offer black color.
I’ve noticed that as well. I don’t know if because Bamub Studio is still using the original PETG Basic which was replaced by the current version, the two versions have very different properties. Each one should has its own profile, but it’ll get confusing fast!
There’s no way it is more matte than HF, at least not with recommended print settings (that still maintain strength). The black especially is very definitely more glossy, the other colors less so, but still not matte (I own most of them now). I don’t know what happened in that video… not to throw any shade, just doesn’t seem to match my own results for finish and quality (admittedly I skipped around in the video as well and don’t know what settings he’s using, if that’s revealed anywhere).
Here’s a terrible example photo… lol… the black joined pieces lying horizontally in the front is HF, everything else is Basic. And yes the Basic really does look more black than the HF in real life, although the HF isn’t really as brown as the camera makes it appear here.
-Max
Check this out, new matte PETG from bambu lab!
I started taking this video with a grain of salt once he started saying:
But a data sheet is one thing, I trust what I’ve actually tested.
It’s like you just said, print settings can affect the gloss. What I’ve learned from a CNC Kitchen video is that you have to print PETG fast to get a matte finish, unfortunately I don’t remember which video. So to compare the surface finish he should have tested the HF filaments with an HF hotend and HF settings, preferably calibrated within the specs of their TDS.
The most recent post from @MaxThreeD somewhat confirms the CNC Kitchen theory. The TDS for BL PETG Basic shows a printing speed < 200 mm/s, BL PETG Matte should be printed < 250 mm/s and the discontinued BL PETG HF < 300 mm/s.
He printed all the tensile samples using the generic PETG profile. (timestamp)
I just ordered one roll of PETG Matte in each colour, and they’re on their way. I’ll post a comparison similar to BL PETG Basic - #31 by Sebo3D1 as soon as they arrive.
PETG Basic is shinier than HF—it’s not even a question. It’s also stronger.
Changing the speed and temperature can affect the finish, but for a fair comparison across a wide range of shapes and to ensure consistency, I think we should use the default profiles. Slowing the printer down to 30 mm/s just to get a matte finish isn’t realistic for most people.
If you have a specific comparison request, drop it below. Has anyone seen a print profile for PETG Matte?
I need to wait for 3rd party tests on this Matte PETG, it looks quite matte to a point where it may be actually weak in layer adhesion. Kinda the same way as BL’s PLA Matte which is extremely weak. The whole purpose of PETG is to have a great interlayer adhesion with decent thermal and great chemical resistance. If any of that is degraded … then it sucks.
However, there are some manufacturers (was it Tinmorry?) that released matte PETG and they were quite OK. So maybe BLs formula is good as well.
That’s pretty much what I use as well… And I print it relatively slow… 100 mm/s for outer walls at most. I’ve slowed it down to 60 and don’t see any appreciable difference in finish. I’ve printed small pieces that get slowed down by layer time to the 10 mm/s minimum, and still basically same finish. ![]()
What I haven’t tried is messing with the extrusion temperature – mine’s in the middle of the range at 245/250 first/rest. The bonding and strength and dimensions are excellent here, so I’m not messing with it yet. So much better than HF ever was.
I agree (and UV) and I totally got bit by this with PETG HF. I asssumed PETG was PETG… nope. HF looks pretty but is (relatively) weak and “dimentionally” crap for functional parts. Learned my lesson to read and compare the specs carefully. The Matte version reads weak (compared to Basic). I wish the marketing hype would at least acknowledge that are going to be trade-offs.
-Max
I’m still on BS 2.5.3.61 can you export filament preset? ![]()
Sure, if you can give at least one good reason to why you can’t just update the slicer.
The only reason I can’t update is my grandfather. He was one of the wisest people I’ve ever known, and he always used to say, “If it ain’t broke, don’t fix it.”
That said, mixing different nozzle sizes might just tempt me to update. I’m ready to battle whatever issues that feature throws at me.
Sorry, I lied—there’s another issue: I print ABS in cooling mode with the air vented outside. Also PETG with PLA supports and manual Aux fans. I had to tweak more than few settings to make it work, and I’m sure a new update would overwrite them, meaning I’d have to spend another few hours getting everything dialed in again. ![]()
