Is there such thing as an impossible clog?
Both of my .4 A1 nozzles are clogged. I’ve done cold pulls over and over. Nothing comes out except a miniscule coating on the Allen key.
I got one of them to the point that I can pass a guitar string all the way through, but as soon as I try to print the extruder clicks and can’t extrude.
Is there anything else I can do or do the nozzles have to be replaced?
I hate to wait a week for a new nozzle. There are third party nozzles on Amazon, but after buying a third party heater assembly last week, I won’t do that again. It was bad.
Heat the hotend to 280* and purge it until whatever is in there comes out & the filament looks good.
On my X1, I sometimes need to heat to printing temp manually, insert extra filament into the nozzle, push in the hex wrench, let it cool to 140° or below, and then pull the key. I usually do that 2-3 times.
Take very special care though. I am not sure how it translates to the A1 and there’s both a very real danger of burn injuries and cable damage. AMHIK :sweat_smile:
Yeah, that has worked for me in the past. I heat the key to red hot and hold the nozzle with pliers, shove it in, let it cool for a few minutes. This time it doesn’t work on either nozzle.
I’ll try 280 C. I’ve never gone above 230.
Just use PLA to try to burn out what is in there. It will probably drip like water for a short time.
nozzle can be striped inside, and it will never be the same again
did you do another type of filament than pla ?
No, only PLA. But I will say…280C blew that puppy right out of there! Thanks!
