Disclaimer: Due to the way my weird brain works, this will be an ongoing thread. Ill be updating this 1st post as I try or learn new things .Hence the massive amount of edits. There will be useful posts by me and other users in below comments, so worth reading on. Also, Im going blind, so bear with me on all the typos. Check back from time to time for new info
I am running beta firmware. And a Amazon.com: SAMSUNG FIT Plus USB 3.2 Flash Drive, 512GB USB Standard Type-A, Speeds Up to 400MB/s / 110MB/s, Portable Storage Memory Stick, Durable Thumb Drive Backward Compatible with USB 2.0, MUF-512AB/AM : Electronics
All packages and both printers came undamaged and setup went flawless. Both printers shipped sokner than estimated. Everything screams high quality and smellls like a new wet suit.
Right now, I have one ams going to one nozzle(white tube). This will be used to hold support materials for pla, petg and abs. Ill use the 4th slot for my main color when/if doing multicolor. Then I have 2 ams going to the other nozzle(grey tube) and the TPU tube (clear tube) going to the side spool holder.
The Tube holder used here is H2D TPU PTFE tube bracket by Viva la vidaMakerWorld: Download Free 3D Models Printed in ABS-GF grey
The camera live view and especially timelapse are both crisp and smooth.
2 small prints used almost 8gb somehow lol
zero issues with the wifi. Liveview pops up fast at a pretty decent frame rate. Files transfer noticably faster than the x1c. 2-3 seconds with my router downstairs. My X1c’s like to pause at 70% for 10 seconds. I live in a congested area and have over 30 things connected to my wireless network
The large air purifier is 64db at 100% and 52db at 50%. Its pretty loud, but it is what it is if you want to
burn things in your home. It comes with 2 extra 1st stage filters.The external filter duct goes over the same exhaust output thats used for cooling the chamber. And it works great still at keeping chamber temps low at low rpm on the internal fan and the external fan turned off, while filtering the exhaust by forcing it through the external filter. As an added bonus, the external duct and tube, muffle the exhaust fan of the printer. So with an external filter and the internal filter installed, all filament exhausts are filtered. I smell zero ABS while using the internal filter only. I dont currently have a way of testing it. It would be super beneficial to set the rear exhaust to 100% for a few minutes at the end of abs/asa/nylon/pc prints to completely clear the chamber fumes through the external filter(if you choose to buy or make one)
Heat up times are better than any printer ive tested.
The chamber heater would heat up even faster if they slowed the fan down a little. Would also make the heater silent. Its the loudest thing in the printer besides the poop chute. A slower fan would allow the heater itself to heat up faster too.
Starting temp 28c on 120 volt
Bed to 90c. 1:12
Chamber to 60c. 15:22
Chamber to 65c. 17:29
Nozzle to 220c. 0:47
Nozzle to 300c. 1:09
Theres plenty of room to add a right side aux fan. The left side aux fan looks like they changed to a side fed blower fan instead of front fed. Less chance of getting something stuck in it or catching a finger tip.
No light flickering or popped breakers. Edit: The breaker did pop. Longer explanation is 2 posts below this one.
I noticed while loading tpu behind abs, it purges at abs print temps. Pretty smart.
Bambu ABS (non cf) stress test. Doubles as a vfa test.
No warp or adhesion loss and I havnt even cleaned the plate since I opened it. No brim or glue used. Top surfaces look beautiful even without ironing. And again with no custom filament or profile tunes. This is what I get “out of the box”
More Abs using ABS support material on 90° overhangs only. This is why the overhangs dont look so hot.
Polymaker PC transparent using tree supports and no interface material. They are full supports and that why the overhangs are nice.
TPU printed at generic pla speeds
Took about an hour and a half with 3 walls, 5 top and bottom layers and 10% 3d honeycomb infill. From Giantarm Transparent TPU. Its more clear in a blue light
Combined 95a TPU with PETG-CF. Air duct quick connect male end.
Model found here
And the other half. Only thing I changed is adding a tpu mating surface. Ill put a coating of ptfe oil on the 2 tpu surfaces.
23 minute benchy in Bambu charcoal PLA. (My favorite Bambu PLA). The benchy looks great. The centauri carbon is the only other printer ive had print such a nice hull line out of the box. This was with no filament tune and filament that hasnt been dried in 2 months even. Printed on ludicrous
mode.
Laser stuff
Cant start any laser operations without holding the top right button down.
To see what its doing, it plays crisp video right on the machines lcd screen.
The birds eye view camera makes placing the etch in the perfect spot super easy. Drag, drop and stretch to fit.
And its so fast(40w). This took a little over 2 minutes and left no smell behind.
7 minutes at 50% power
Sacrificed a cool plate to the cause. Took 33 minutes. Still no visible dust in the printer.
You could definitely etch a company logo onto a plate for transfering to prints. Probably qr codes and bar codes too.
Ill add to this thread as I go, but I highly doubt I’ll find many flaws. The only ones ive found so far is that the top glass is painted black on the laser edition and the estop mounting is nonexistent, so when you move the machine, it falls off. Not exactly a deal breaker. They should have also made a nice way of mounting 4 to 1 couplers.
Edit: Im now getting live view camera calibration failures. The original calibration before this last firmware update did pass though. Ive read that it could be a loose cable or possibly the firmware update caused it.
