Just finished a clean print of the Minimalist Enclosure for the P1P
Hello there,
i may present you my newly finished custom, minimalistic modplates (soon to be enclosure) for the P1P
since i’m still waiting for the polycarbonate sheets to arrive, this is just the “naked” shell without any panels around
tell me, what you think :slight_smile:
if you like it, you can get the files over on printables
Very cool.
I’m pretty jealous of p1p users that they get this opportunity to customize their device.
Theoretically it retains chamber temp better than the X1C’s metal enclosure due to conductivity? Potential added bonus.
i assume you always can put some reflectiv aluminium insulation on the inside of your X1 to be more energy efficient
would be nice if someone actually would test, if the P1P or the X1 is more energy efficient - since the X1 prints on a Cool Plate and the P1P on the PEI-Sheet by default, the energy required to heat up the bed is worse on the P1P
That’s true. This is part of the reason I continue to use Cool plates when I can (not to mention the time saved by not having to bring the bed to temp).
I put some thermal barrier on the inside of one side of a single x1c unit, but I was too lazy to do the other sides because the electronics make it more complex :sweat_smile:
It was just something I picked up from Daiso (dollar store) that is meant to lay on top of your bathwater to keep it warm. Sort of like this;
I have the same type of enclosure , instead of polycarbonate panels i went with just aluminum sandwich sheets which i work with everyday.
looks very nice with this colors - like corten steel or something like that
since there is still a gap above your door: i’ve added piece to the model to cover this gap (current version is DOOR_FRAME_v45.3mf over on printables)
btw: would you mind posting your image as a make over on printables? it looks amazing
Nice. Love those side panels. Wish I could find some like it. Can only find white so far.
Where are you located? I have couple left over because I printed few extra, i can send them to you.There is opening on one side for WyzeCam
looks good! printed in PLA?
Hello suit.
The new p1p-to-p1s-upgrade-kit
does not have transparent side panels. Would it make sense to use
printables 381777-bambu-lab-p1p-minimal-enclosure-x1-door
as the starting point for a “Most Minimalist Enclosure” that uses most part from the upgrade kit but replaces the left/right plastic panels with FRONT|REAR_LEFT|RIGHT_top|bottom parts from your set? REAR would have to be clipped (if not redone) but FRONT should work as-is?
yeah, this should be possible - but unfortunatly i don’t have access to the new pack panel of the P1S - it is available from mid october in the store
when it is availaible, i’ll order it and make an iteration of the design
This looks pretty awesome, I love the whole aesthetic and the color choice compliments it great! Love to see an update on this once it’s completed.
Very Nice. I printed my first shell from the default wrap on the P1P 3d model from the wiki. Just for temporary until I decide what colors to use for the “real” one.
Since you are enclosing, what filament did you use? ABS I assume?
i printed everything out of matte PLA - i was prepared to replace it in the future, but no warping or deformation whatsoever so far
