Latest recommendations for "failed to pull out the filament"?
I’ve had my X1+AMS for a year but never used it to print multi-colors until a couple of weeks ago. The one and only print I tried worked flawlessly. Fast forward to this weekend, every single multi-color print fails with “failed to pull out the filament from the extruder…” when switching from one color to the next From this forum and Reddit, this seems to be a common error, but not one solution. Of the things I’ve tried, it hasn’t made a difference.
Additional Info:
  • If I click retry 2-4 times then I can usually get it to release
  • If I wait and let the printer cool down and click retry, then it works (only test a few times)
  • If I press the PFTE collar down at the hotend and yank out the PFTE tube, I can get it to “release” and then it retracts just fine. When I do this the PFTE comes out with some of the filament exposed. The end has a thin little “tail” which I think means it was still in the “throat/heat break”.
  • I also found if I tap/bump the PTFE Extruder Bracket while it’s trying to pull back that will “release it”.
  • There’s never a clog, but it does feel like it’s “stuck” in the extruder and not upstream toward the AMS
  • I removed my Y-splitter, but no change
  • I printed the Bambu X1 PTFE Extruder Bracket but no change
  • It happens with BambuLab brand PLA (plastic spool) and Overture (cardboard spool) and happens in all four slots.
  • I’m printing with the glass off and the door wide open.
So, what else should I try? I really don’t want to deal with BambuLab support so hoping you guys have some wisdom.
Have you checked out the extruder? Especially the filament sensor. Make sure all your ptfe tubing is cut square and fully seated.
Besides a square end on the PTFE tube what should I be looking for in the filament sensor?
Check if the PTFE tubes need replacement: PTFE Tube Wear in AMS and Maintenance Recommendations | Bambu Lab Wiki
Lots of dust, maybe a very small piece of filament. The switch is moving free and not hanging up on one side or the other.
I have 5 X1C’s running and was getting this non-stop. I tried a whole bunch of fixes and after doing these: AMS Fix Failed To Pull Back Filament Error by SPStudio - MakerWorld I don’t think I have had a single issue in the past 3 months. I put the update design in the bottom of each AMS to align to tubes plus I put the plastic bracket before and after the buffer to hold the tubes straight in. There are a few versions, I printer one that also holds the AMS cable neatly as well. Highly recomended.
