Lighting Mod that Connects to Board
How is it possible that your measurements are so different from mine? I am quite new to electronics stuff but, as I said, I measured 800 mA with two different devices on the new Juupine strip.
/edit: By looking at the pictures I just realized that there are two “new” versions. One where the LEDs are just further apart than on the old (my new version) and one where they left out every other LED and resistor (your new version).
Also, it looks like all the listings by Juupine have updated product images and are all the same version now.
Now the question is:
Do i keep the old and already installed strip and buy a relay to make it AP board friendly
Or do i use the new strip which already is AP Board friendly but lose out on brightness + need to install it first.
At least with the relay you could update the LEDs without worrying about the AP getting smoked.
Amps, resolution and watts oh my! :nerd_face:
interestingly enough i tested the strip on both.
The USB Port got stupid hot when the strip was used there
The AP board did not get hot when the strip was connected to that directly.
The track width on the usb connection vs. Were you connected on the AP was different probably. Just guessing really. :man_shrugging:
Yeah, i’m assuming that it has something to do with the pcb traces. Tough i’m still not going to run the risk of using 5x of the rated power from that port.
well i just remembered that my USB Port is already occupied by the Xtouch.
sooo…hmmm
Bigtreetech has been teasing an dual port adapter.
Hooking up both to the connector wouldn’t be a problem. The amount of power i am pulling is my concern, alongside the generated heat.
I need to test if the USB port actually only supplies 1.5a or if it allows much more like the AP board light.
Otherwise I’ll go with external power.
As the new 0.3A Juupine LED stripe version seems to be legit, i’ll connect that one instead of the original LED. I’m aware that it may not be as bright as the other offered LED stripes that pulls more power and could fry the electronics of my printer.
The 0.3A version should be better than the original simlpy because the light is coming from all sides.
And for the case that it’s not bright enough I’ll add a LED stripe with external power supply that will be placed into the Riser for the AMS I want to print. So that I can turn this one on if more light is needed.
Also the chance that there is a issue with the lidar should be reduced with the 0.3A version.
Hi Ikraus, Could I ask for a little detail on the components you used as there are a number of options on the Aliexpress links you supplied. What width LED’s and which pin connectors would you suggest I purchase?
Many thanks in advance
Aiden
I bought:
10Pairs JST 1.25 Male Female Wire Connector Pitch 1.25mm 2P
LR7843 Isolated MOSFET MOS Tube FET Module Replacement Relay
COB LED Tape Light Bar Natural White, 320LEDs 8mm 24V, 2m
The adhesive on this light strip worked for a few months of printing with PLA, PETG and TPU. The lights remained in place after I made some prints with ASA, with chamber temp around 56°C, but then it let go a couple days later, when hot weather raised shop temperature to about 35°C.
I’ve cleaned off the old adhesive and replaced it with 3M 3/8-5-468MP Adhesive Transfer Tape, It has not yet been exposed to high temperatures, but 3M claims it should withstand 149°C for weeks.
I printed a small open box to hold the relay. The box and the relay are mounted using 3M VHB automotive trim tape that I had on hand. There may be a better method, but it works so far. Wiring connections were made with the male and female JST connectors and some solder seal wire connectors (similar to these).
I still do not have a picture of the mounted relay or wire routing, but I do have a shot of the Y connection I made to connect the relay trigger wire and the stock light to the AP connector.
Absolutely brilliant, thank you
Just to give my personal update on this:
I ordered a Relay and installed it like others here already did.
Printed out some tiny “LTT” cable arches with magnets and cable managed it.
Quite a bit of wires since i also run xtouch and a temperature sensor.
Came out clean in my opinion.
You also mention that you do not have an AMS. Just to be clear, the unused 24V connection is still unused if you do have an AMS, right?
I would expect so, I did not leave anything disconnected and I certainly expect to be able to plug in an AMS. Bambu sells their printers with/without AMS but does the printers are always AMS compatible.
Late to the party here but thanks for your post.
I’ve been running a color accurate 24v LED halo in the riser for quite a while but have seen the lidar error regularly so when I tripped over your post, I decided to followed your lead.
Thanks :slight_smile:
I made made my own ‘Y’ cable with 1.25mm JST connectors from Amazon (I’ve been meaning to get some of these micro sized JST’s for a while).
My X1 puts out 4.86v to the stock LED light bar. I worried about adding more current draw to that circuit so I used a small relay (SIP1A-05) with a 200r resistor to limit the draw to 6mA or so. (The relay tested out needing just 5 to switch). I used a screw terminal for the resistor just in case something changes in the future.
So 1.25 Female JST to the X1 LED cable, parallel male back to the AP connector and a third in parallel to the 200r resistor and the SIP1A-05 internal reed switch. I made a little vented box to hold that bit and tucked it next to and behind the console display with the relay switched pair cable running behind the front support beam to a Dupont connector for disconnecting. I cut a groove out of the underneath of the riser for the rest of the cable length for it to extend to the back right corner where I could splice into the 24vLED power feed cable.
I looked at the BLLED product but was lucky to see a caution in one video that it was not working with multiple AMS’s not to mention shipping to Australia. So your approach is working here now and life is good again.
Thank you :slightly_smiling_face:
Reading through all of these posts, I cringe just a little at the amount of work involved.
check out the BLLED solution it’s rediculously simple, wireless and works with the built in controls from bambu handy and studio.
How did You mount up that led? Do you have stl or can you point me where to look for them?
I purchased a kit from my local hobby shop that came with the clips and the lights as well as all the sticky clips to hold up the wires.
