I did not take any pictures and I do not currently have time to disassemble the printer, but maybe this will help. (I need to apologize to somebody that sent a private message about this. I delayed my response with the intention of taking pictures but time just got away from me. Can’t find the message now in my mail)
The relay is delivered in three pieces, two sets of screw terminals and a circuit board. You will need to solder the terminals to the board, because $0.70 is too little to cover any labor costs.
28 Volts from the vacant connectors on the power supply connect to screws 1 and 3 on the blue block.
The 28 Volt LED light strip connects to screws 1 and 2.
I soldered some of the JST connectors to make a splitter (1M & 2F) that plugs into the AP board, one side goes to the chamber light and the other to a wire (w/JST connector) to trigger the relay. So, no need to cut any of the wires and the mod can be removed by just unplugging.
The trigger wire connects to the PWM (+5V) and GND terminals.
All the wire is two conductor 28 gauge, routed alongside other wiring for the most part. Twist the +28V feed and the LED + wire together and they both fit (barely) into the relay terminal.
I printed a small box to hold the relay - not certain it’s needed, but it looked kind of naked and exposed. Relay and box are mounted with double stick automotive trim tape, because I had it on hand and I think it will survive high temps.
The relay is inside the back of the printer, just above the chamber fan. (Not my picture)
I used the Wiki for heat bed replacement as a guide to remove the back panel and the power supply cover. There are lots of different screws. Print the pictures from the wiki, insert the screws in the paper at the correct location to keep them straight.
The wire from the relay to the LED exits the back panel and goes up into the rear of the riser. Another pair of JST connectors here on the outside can be unplugged if I need to remove the riser or the back panel for maintenance. I have no AMS so there were several holes available in the back panel and I picked one that a JST connector will fit through.
I’m not real happy with that wire on the outside of the printer, but that worked best with my riser and has not caused any issues yet.
There may be better relay choices, or better mounting locations, but this has provided plenty of light and no LIDAR issues. It was also pretty inexpensive, with components from AliExpress.
