Lines in top layer
Hi
I’ve tried finding solutions in older forums posts but noone have helped. I get these “travel lines?” in the top surface when i print the model.
I am using Bambu lab PETG-Basic thats been calibrated and printing with 0.12mm layer height and ironing with 20% flowrate. I know that i have to adjust the flow ratio to get a better surface layer but thats another problem. I’ve tried adjusting top surface pattern, lowering iron speed, adjusting line spacing, deselecting reduce infill retraction.
I dont really know what to adjust anymore so i am here asking you for help.
Your problem is with the surface layer.
What are you waiting for?
Yes, thanks. What parameters do you suggest adjusting? Do you think the flow-ratio is the cause of the lines?
There are multiple posts on this problem.
This is one.
You wish to take a look through those.
There are some suggestions to resolve the issue, some better than others.
Nothing perfect though.
I saw a Bambu employee suggest turning off one wall on top surface to fix lines like that under text. They are working on a proper solution for a future slicer update.
Yep, this solved the problem. Thank you for fast and helpful respone :smiley:
That’s great that it worked for you. I haven’t tried it yet so it’s good to know that it actually works.
Discussed extensively on Github is a solution called “Interface” shells that is in the Beta:
