Loaded STL files in bambu Studio say that no geometry data!
Some people getting so upset at this and I have no Idea why.I just wanted to say thank goodness for this! I have been printing for a couple of years with a rubbish Creality printer and have recently upgraded to a P1s and started looking into creating models, I have twin babies and zero experience so this is just a self taught hobby and I could not for the life of me understand why anything I made had this issue. I thought that the ‘project’ tab meant that there was a CAD feature to the software and if I wanted to be able to print from the bambuhandy app I had to model exclusively from there. Nope! I couldn’t really understand and there isn’t a lot of information about it that’s understandable for someone new. I have twin 7 month old babies so often use my mobile to monitor my prints and start prints wherever I might be in the house. This post was a lifesaver for a learner, thank you!! To the people getting upset that theres a post with a question and answer in one post, you need therapy.
I dont know if this is still relevant, but i had the same issues. I did directly export is from Fusion 360 into Bambu slicer. when i did this i notced windowds defender pop up about blocking some app. i checked and saw that windows defender was blocking fusion and bambu lab. allowing both aps manually fixed the problem for me!
Bambu Slicer for linux fails to open any STL file. Even a simple cube from OpenSCAD. The same files open successfully when using Bambu Slicer for Windows.
When I save a project on the latest bambu studio for windows then try to open the same project in bambu studio for windows (installed via flatpak) I get this error.
Debian 12, bambu slicer installed via flatpak via:
flatpak install flathub com.bambulab.BambuStudio
The following was in the logs when loading the file:
025-04-21 15:14:33.618420[Thread 0x00007fd84594d480]:update_printer_preset_name 6569start update preset_name
2025-04-21 15:14:33.618664[Thread 0x00007fd84594d480]:The values of tray_info_idx and tray_type do not match tray_info_idx  tray_type  system_type
2025-04-21 15:14:34.035844[Thread 0x00007fd84594d480]:OnDropFiles: drag 1 files into app
2025-04-21 15:14:34.036069[Thread 0x00007fd84594d480]:load_svg,/run/build/BambuStudio/src/slic3r/GUI/Plater.cpp,fail:/mnt/3d_printing/printable files/art frames and easels and equipment/frames/frame_spacer.stl
2025-04-21 15:14:34.036088[Thread 0x00007fd84594d480]:load_files: normal_paths 1, gcode_paths 0
2025-04-21 15:14:34.036192[Thread 0x00007fd84594d480]:Undo / Redo snapshot taken: Load File: frame_spacer.stl, Undo / Redo stack memory: 0MB Resident memory: 616MB; Shared memory: 243MB; Private memory: 373MB; Peak memory usage: 623MB
2025-04-21 15:14:34.036254[Thread 0x00007fd84594d480]:get_enable_print_status: m_print_select 1, enable= 0
2025-04-21 15:14:34.036274[Thread 0x00007fd84594d480]:get_enable_slice_status: m_slice_select 1, enable= 1
2025-04-21 15:14:34.036280[Thread 0x00007fd84594d480]:update_slice_print_status m_slice_select 1: can_slice= 1, can_print 1, enable_slice 1, enable_print 0
2025-04-21 15:14:34.036343[Thread 0x00007fd84594d480]:load_files: load_model 1, load_config 0, input_files size 1
2025-04-21 15:14:34.115761[Thread 0x00007fd84594d480]:load_files: is_project_file 0, type_3mf 0
2025-04-21 15:14:34.115818[Thread 0x00007fd84594d480]:stl_open_count_facets: Couldn't open /mnt/3d_printing/printable files/art frames and easels and equipment/frames/frame_spacer.stl for reading
2025-04-21 15:14:34.115995[Thread 0x00007fd84594d480]:select_view_3D4892select view3D
2025-04-21 15:14:34.116000[Thread 0x00007fd84594d480]:set_current_panel: current_panel 0x5622dd7a7360, new_panel 0x5622dd7a7360
2025-04-21 15:14:34.116007[Thread 0x00007fd84594d480]:set_current_panel: the same panel, exit
If I load the file my own user’s home folder in linux, it works. If I load a file anywhere, it fails. For example, if I have a network share mounted via /etc/fstab, even if it has the proper permissions, it fails to load. I have to copy the files to my local home folder first. If this is an electron app it may have something to do with electron not being able to access the files?
What does software gets retired for a reason mean ???
Hey man, I was experiencing this problem today and I subscribed to this website full of haters just to get you an answer even 2 years later
It appears that copying the file on a usb key corrupts the reading of this object. I tested the Original version of the STL output from Blender, this was a 2d part of an object already printed succesfully but transfered via email. The duplicate file on usb was opened on 3D viewer app even on the same computer and was returning error, the original opened succesfully.
try another way of transfering the stl file that doesn’t involve copying.
Hope this helped
