Loading before resuming after filament change
Hi,
System: P1P without AMS.
If the filament roll runs out in a print, you get a message in the Windows app or the mobile app. If you then insert a new filament roll and insert the filament, you can continue printing.
Before that, however, you have to load the new filament manually. If this is not done, there is a gap in the print. It is a pity if this happens at a critical point.
Here it would be great if the printer, as with the print start, also performs a load run. Through the error message, the printer knows that filament was changed here and can classify the situation.
Then you could just tap Continue on the cell phone after the change and the print would simply continue.
