Gonna charge this shot cause it is the same topic and same issue without any real solution. I did search on the forum with no luck if not from this post wich is just a workaround and not a fix, and I would like to fix it correctly cause I don’t want to disable an useful feature I might need. I wrote in that topic but I didn’t receive any answer.
I might also link it so you can check the video. Same exact behavior
The temporary fix works by disabling the extruder clog checking but I would like to have it on… it worked like a charm unito I just changed a filament like I do a lot of times.
Please help!
